Cisco 2811 and HWIC card
Hello All
I have a Cisco 2811 with IOS
C2800nm-ipbase-mz.124-3i.bin
I installed HWIC 1CE1T1-PRIA Card on it but I can not see in the config.
I tried many cards and slots on the router but still can not see
Any idea?
Thx
Ersin
Re: Cisco 2811 and HWIC card
The Minimum IOS requirement for the above card is 12.4(11)XW4 or 12.4(20)T
Upgrade the IOS and check again
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/product_data_sheet0900aecd80710c88_ps5949_Products_Data_Sheet.html
Narayan
I used the
c2800nm-ipbasek9-mz.124-20.YA1.bin
I can see the card during boot but not in the configuration ?????
Here is the line during boot
mart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0003E7 0X00473800 C2811 Mainboard
000529 0X00164800 1 port channelized and PRI T1/E1 HWIC
0X000021B8 Onboard USB
0X002C29F0 public buffer pools
0X00211000 public particle pools
TOTAL: 0X00AADBA8
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 12Mb.
Using 4 percent iomem. [12Mb/256Mb]
Weird thing is even it is working and can bee seen in the config serial module is not here ???
Can you post a sh diag from your device
Narayan
I am booting with 12.4-20T1 I will post it in 5 mins
Ok problem solved
Thx for helping
Good to know that the problem has solved
Narayan
590
