cisco 2811 + HWIC-4ESW 4 routable networks
elmin.skrobo
i have cisco 2811 and HWIC-4ESW is there a way to create config to have 4 routable networks, two networks on integrated interfaces and 2 networks on one of 4 interfaces of HWIC-4ESW card. and all networks should be route traffic when i configure 4 gateways on interfaces. so i need 4 routed networks 2 connected on integrated int. and 2 on HWIC-4ESW card. does networks from integrated interfaces can route traffic to routable two interface on HWIC-4ESW.
Edison Ortiz
On HWIC-4ESW interfaces, you need to assign port membership and a SVI.
interface f1/0
switchport mode acess
switchport access vlan 10
interface f1/1
switchport mode access
switchport access vlan 20
interface vlan 10
ip address A.A.A.x x.x.x.x
interface vlan 20
ip address B.B.B.x x.x.x.x
and the regular interfaces, just directly enter the IP address there.
Routing is enabled by default and the interfaces above will be listed in the routing table as 'connected'.
End devices should point to this router as the default gateway on their respective subnets.
HTH,
is this same situation with HWIC-D-9ESW card, probably it is.
Yes.
