09-05-2006 09:20 PM - edited 03-03-2019 01:53 PM
I'm trying to install a VWIC 1MFT E1 card in a Cisco 2811 Router . The problem is that I can only get a max of two channel groups while I need all the available groups(even 30). Any suggestions someone?
09-06-2006 03:52 AM
Though i have not worked with MFTE1 card in 2800 platform, it Sounds very strange.
Can you let us know what the IOS version that you are using?
Can you provide the controller configuration that you have tried?
Are you getting any error message when you configure a new channel group?If so can you post the error message also here for us?
-VJ
09-06-2006 07:09 AM
This is a limitation of the multiflex cards.
Unfortuantly they bury the statement in a document that discusses all the different models of these cards.
You are only allowed to have 2 channel groups per card and this includes the cards that have 2 physical ports. If you put 2 channel groups on one of the ports you cannot put any on the other one.
09-14-2006 03:19 AM
Hi TDRAIS,
Thanks for your response.
I seem to have one other puzzle:- This same type of card is already working for me very well but in a 3825 Router whereby I can access all the channel groups!
Any further insights??
09-14-2006 03:05 AM
Hi VJ
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.3(8)T8, RELEASE
SOFTWARE (fc1)
ERROR MESSAGE:
%Channel-groups per port limit exceeded
%Insufficient resources to create channel group
Hope this will do , thanks
JN
09-14-2006 05:46 AM
Hello Nyapuodi,
Have a look at the following. It seems it is a bug that is in the 2800 series router. I hope it helps.
You will need to upgrade to "IOS 2.3(11.4)T"
