Cisco 2811 teminating 10MB ISP connection
I intend on using a 2811 to terminate my 10MB ISP connection at our headoffice. The router is going to be running BGP and QOS and will maintain routes for 6 remote sites (no internet routing table)
Does anyone forsee any problems with the 2811 in this regard. Will the performance on the 2811 be sufficient?
Many thanks
Hall of Fame Super Gold
Re: Cisco 2811 teminating 10MB ISP connection
A 2811 should be able to all that with no issue.
123
