Cisco 2811 w/ NM-ESW-16 Config for VLAN & WAN comms?
neill.clark
Anyone seen config assistance docs for back-to-back Cisco 2811's (simulated WAN w/ cross-over cable attached to Fa0/1) when using the network modules' access ports on each router, on common VLAN, to communicate across the WAN? (Cisco's one config example for NM-ESW-16 doesn't explain how to config for egressing to a WAN for comms w/ a similar router/NM-ESW hardware combination.) Thanks, in advance.
paolo bevilacqua
What is exactly that you want to simulate ? There is nothing special in the module, imagine that the VLAN router interfaces are connecting to a switch that you also configure under their respective interfaces.
Then it depends what do you mean by WAN connections, as thereare of various types.
