02-20-2009 12:23 AM - edited 03-04-2019 03:39 AM
i required module of 2 fast ethernet to support 2811 router. can pls tell me
02-20-2009 02:05 AM
hwic-4esw. Note, it's a switch module.
02-20-2009 04:54 AM
There's also the HWIC-1FE, you would need two, which the 2811 supports.
02-20-2009 07:24 PM
You want a routed port(s) or switch port(s)?
If switch port(s), see Paolo's comment. If routed port, see Joseph's comment.
You can also verify any future network modules (NM & WIC) cards if they are compatible to your router:
Relevant Interfaces and Modules for the Cisco 2800 series routers
https://www.cisco.com/en/US/products/ps5854/products_relevant_interfaces_and_modules.html
Overview of Cisco Network Modules for Cisco Access Routers
