Webcast-Catalyst9k
cisco 2811
i required module of 2 fast ethernet to support 2811 router. can pls tell me
Hall of Fame Super Gold
Re: cisco 2811
hwic-4esw. Note, it's a switch module.
Super Bronze
Re: cisco 2811
There's also the HWIC-1FE, you would need two, which the 2811 supports.
Re: cisco 2811
You want a routed port(s) or switch port(s)?
If switch port(s), see Paolo's comment. If routed port, see Joseph's comment.
You can also verify any future network modules (NM & WIC) cards if they are compatible to your router:
Relevant Interfaces and Modules for the Cisco 2800 series routers
https://www.cisco.com/en/US/products/ps5854/products_relevant_interfaces_and_modules.html
Overview of Cisco Network Modules for Cisco Access Routers
http://www.cisco.com/en/US/docs/routers/access/interfaces/nm/hardware/installation/guide/OvrNetM.html
144
