Cisco 2821 couldnt able to found ATM Interface
reachrahaman
Dear All,
Im using Cisco 2821 with
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(7a),
RELEASE SOFTWARE (fc3)
With System image file is "flash:c2800nm-advipservicesk9-mz.124-7a.bin"
I want to Configure router with ATM Interface when i type INTERFACE ?, i couldnt able to find ATM but instead XtagATM.
How can i resolve this problem.
Abdul
5 Replies 5
mohammedmahmoud
Level 11
Level 11
Extended-label ATM interfaces are virtual interfaces that are created on first reference like tunnel interfaces. They are similar to ATM interfaces except that they only support TC-ATM encapsulation.
What kind of interface have you inserted into the router.
HTH,
Mohammed Mahmoud.
Thanks for your feedback.
Im having a DSL line from a Service Provider which is connected to DSL Modem which is configured as BRIDGE connected to Cisco Router 2821.
I Have to make following configuration.
interface ATM0/0.35 point-to-point
ip address 172.31.1.146 255.255.255.252
pvc 0/35
encapsulation aal5snap
router bgp 64659
neighbor 84.x.x.209 remote-as 65000
no auto-summary
How can a resolve this issue...
Abdul
If you have HWIC-1ADSL, the minimum IOS is 12.4(4)T, so you have to upgrade your image. See: http://cisco.com/en/US/products/ps5853/products_data_sheet0900aecd80394b7e.html
Sir,
I have installed HWIC-1ADSL Card.
But its not detecting.
Im having following version.
I want to know that above version will support for ATM Interface or not.
(and)
Im confused about IOS Version becoz im have IOS 12.4(7a), cisco suggest minimum IOS is 12.4(4)T.
Which is the latest one.
Kindly update me what to do next.
Abdul
Ur IOS image not currect, u should select proper image which supports atm interface.
best regards
Om
