Bronze
Cisco 2821 high CPU with Multicast
I have two Cisco 2821 that I tried to use for MCAST but once MCAST traffic is enabled, the CPU goes to 98% and the HSRP process starts to flip flop between both routers. Could the 2821 routers be used for MCAST?
Bronze
Re: Cisco 2821 high CPU with Multicast
on your interfaces do you have ip mroute-cache? if not try adding that - also make sure CEF is enabled.
Bronze
yes, I do.
Bronze
what is the bandwidth of the stream?
Bronze
the problem seems to be with over subscriptions. We are dropping a significant number of packets once we turn on MCAST.
Bronze
so all you are doing is configuring pim? No multicast flows? If you have a flow how much is the pps total? The reason i ask is i have destroyed a 7200-npe-g1 with a 1-10mb flow of multicast.
Bronze
If I understand your question. Yes, I only have ip pim rp address and ip pim sparse-mode configured on the device.
Below is part of the sh int output after clearing the counters.
Last clearing of "show interface" counters 00:03:48
Input queue: 4/75/35053/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 3767000 bits/sec, 3667 packets/sec
1300612 packets input, 172618718 bytes, 0 no buffer
Received 1300319 broadcasts, 0 runts, 0 giants, 7825 throttles
Bronze
I resolved the problem. The routers' CPU were clearly not able to handle multicast so I redesign the network to use the 3750G switches.
171
