Cisco 2821 router
nachoguapito
hi i got problem with my upload very slow.
when i check in speedtest.net download 10mb upload .10mb , when i remove the router and connect direct to computer. upload and downloads is fast 10mb for download and 6mb upload.
router 2821.
my config:
Code:
Building configuration...
Current configuration : 1498 bytes
version 12.4
hostname router1
boot-start-marker
boot-end-marker
enable secret 5 $1$v099$O3hUq1RShonkrqFQQfE0o.
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.100.60.0 172.100.60.209
ip dhcp excluded-address 172.100.60.241 172.100.60.255
ip dhcp pool DHCP
   import all
   network 172.100.60.0 255.255.255.0
   domain-name network.com
   default-router 172.100.60.1
   dns-server 172.100.10.2
   lease 7
ip name-server 172.100.10.2
ip name-server 172.100.10.1
interface GigabitEthernet0/0
ip address 172.100.10.10 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
hold-queue 100 out
interface GigabitEthernet0/1
ip address 172.100.60.1 255.255.255.0
ip nat inside
duplex auto
speed auto
hold-queue 100 out
ip classless
ip route 0.0.0.0 0.0.0.0 172.100.10.2
ip route 10.10.0.0 255.255.0.0 172.100.10.215
ip route 10.20.0.0 255.255.0.0 172.100.60.10
no ip http server
no ip http secure-server
ip nat inside source list 10 interface GigabitEthernet0/1 overload
access-list 10 permit 172.100.60.0
access-list 10 permit 172.100.60.0 0.0.0.225
snmp-server community public RO
control-plane
line con 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
end
11 Replies 11
kcnajaf
Level 7
Level 7
May i ask you how is your connectivity looking like? I mean to what device this router is connecting to?
Najaf
connected to microwave link from another office of ours.
Hi Nacho,
Do you know the micro wave link output support 1000Mbps..If it doesn't try manually configuring your router interface with speed 100 and duplex full.
Coming back to your configuration your outside interface (from NAT's prespective) is showns as GigabitEthernet0/0 and inside interface as GigabitEthernet0/1.
Your NAT statement shows your Natting to the inside interface. Is this not suppose to be outside interface like as below. May be i'm wrong but worth cross checking the same.
ip nat inside source list 10 interface GigabitEthernet0/0 overload
Hope that helps
Najaf
Please rate when applicable or helpful !!!
if i manually change to full duplex connection will be drop.
and i change it to " ip nat inside source list 10 interface GigabitEthernet0/0 overload" no effect still. do i need to reboot?
After NAT change you don't have to reboot. Is Internet still working after the NAT statement change?
Have you tried changing speed and duplex to confirm the connection is completely dropping? I agree that there would be a momentarily drop
Could you please share below outout from router?
show inter gi0/1
show inter gi0/0
show nat trans
Hope that helps
Najaf
GigabitEthernet0/0 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 001b.542c.d530 (bia 001b.542c.d530)
  Internet address is 172.100.10.10/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 2/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is T
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1092000 bits/sec, 160 packets/sec
  5 minute output rate 229000 bits/sec, 116 packets/sec
     164226 packets input, 131733466 bytes, 0 no buffer
     Received 8136 broadcasts, 0 runts, 0 giants, 0 throttles
     1 input errors, 0 CRC, 0 frame, 0 overrun, 1 ignored
     0 watchdog, 0 multicast, 0 pause input
     131598 packets output, 23265052 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 1 pause output
GigabitEthernet0/1 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 001b.542c.d531 (bia 001b.542c.d531)
  Internet address is 172.100.60.1/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Full-duplex, 1000Mb/s, media type is T
  Input queue: 1/75/0/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 237000 bits/sec, 117 packets/sec
  5 minute output rate 999000 bits/sec, 139 packets/sec
     141359 packets input, 25140302 bytes, 0 no buffer
     Received 8076 broadcasts, 0 runts, 0 giants, 0 throttles
     157131 packets output, 131853487 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 0 pause output
Pro Inside global      Inside local       Outside local      Outside global
tcp 172.100.10.10:3283 172.100.60.1:3283  172.100.10.209:61218 172.100.10.209:61218
tcp 172.100.10.10:3283 172.100.60.1:3283  172.100.10.209:61219 172.100.10.209:61219
tcp 172.100.10.10:3283 172.100.60.1:3283  172.100.10.209:61220 172.100.10.209:61220
tcp 172.100.10.10:3283 172.100.60.1:3283  172.100.10.209:61222 172.100.10.209:61222
tcp 172.100.10.10:50037 172.100.60.66:50037 173.194.36.1:443 173.194.36.1:443
tcp 172.100.10.10:50058 172.100.60.66:50058 173.194.36.3:443 173.194.36.3:443
tcp 172.100.10.10:50059 172.100.60.66:50059 173.194.36.9:443 173.194.36.9:443
udp 172.100.10.10:53314 172.100.60.71:53314 64.4.23.157:40035 64.4.23.157:40035
udp 172.100.10.10:53314 172.100.60.71:53314 65.55.223.32:40001 65.55.223.32:40001
udp 172.100.10.10:53314 172.100.60.71:53314 100.68.217.129:34661 100.68.217.129:34661
udp 172.100.10.10:53314 172.100.60.71:53314 111.221.74.16:40001 111.221.74.16:40001
udp 172.100.10.10:53314 172.100.60.71:53314 111.221.74.21:40018 111.221.74.21:40018
udp 172.100.10.10:53314 172.100.60.71:53314 111.221.74.32:40001 111.221.74.32:40001
udp 172.100.10.10:53314 172.100.60.71:53314 111.221.77.142:40033 111.221.77.142:40033
udp 172.100.10.10:53314 172.100.60.71:53314 157.55.56.149:40046 157.55.56.149:40046
udp 172.100.10.10:53314 172.100.60.71:53314 157.55.56.160:40032 157.55.56.160:40032
If you could answer my previous questions please? i.e.
Currently i can see GigabitEthernet0/0 is auto negotiated to 100 full..Hope this is the interface you are using to connect to micro wave link. I would suggest you to set the speed and duplex manually and try the speed test..
Hope that helps
Najaf
yes working
i tried manually change duplex to full and speed to 100 it will completly drop connections.
nachoguapito
Anyone have another idea? please help..
Is this link used only to access Internet? Or intranet as well?
Do you have any PC with two network card? If then we could try ICS by completly avoiding the router?
Another option you could try is upgrade the IOS image on the router to verify if that help.
Hope that helps
Najaf
nachoguapito
Thanks all we solve this problem already , Firewall problem from the other side with the office.
