Cisco 2821 suddenly reboots
Teh following output is generated by sh context
System was restarted by bus error at PC 0x41FE4988, address 0x813B at 10:07:23 EEST Wed Aug 29 2012
2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(20)T1, RELEASE SOFTWARE (fc3)
Compiled Wed 24-Sep-08 14:37 by prod_rel_team
Image text-base: 0x400783C8, data-base: 0x43DC3FC0
Stack trace from system failure:
FP: 0x47D46830, RA: 0x41FE4988
FP: 0x47D46888, RA: 0x41FDFF34
FP: 0x47D468C0, RA: 0x41E1337C
FP: 0x47D46920, RA: 0x41E15CC4
FP: 0x47D46998, RA: 0x41E16650
Fault History Buffer:
Signal = 10, Code = 0x46D40000, Uptime 1d16h
$0 : 00000000, AT : 000000BA, v0 : 00000007, v1 : 00000008
a0 : FFFFFFFF, a1 : 47545AD4, a2 : 4008DAC0, a3 : 00000000
t0 : 00000008, t1 : FFFFFFFF, t2 : 00000001, t3 : 00000815
t4 : 00000814, t5 : 00010000, t6 : FFFFFFFF, t7 : 00000002
s0 : 0000FFFF, s1 : 47545AD4, s2 : 4008DAC0, s3 : 00000814
s4 : 00000000, s5 : 46AF0000, s6 : 46980000, s7 : 3F201898
t8 : 46530000, t9 : 46D338F0, k0 : 3040A801, k1 : A000F000
gp : 46986C40, sp : 47D46830, s8 : 00000000, ra : 41FDFF34
EPC : 41FE4988, SREG : 3400FF03, Cause : 00000010
Error EPC : BFC00E8C, BadVaddr : 0000813B
CacheErr : 903FFFC0, DErrAddr0 : 07069DC8,
                            DErrAddr1 : 07EABCE0
DATA_START : 0x43DC3FC0
Is this a hardware or software problem?
Everyone's tags (3)
VIP Purple
Hi Milen,
This is the problem with IOS.
Upgrading the IOS will solve this problem.
here is the link of troubleshotting:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800cdd51.shtmlhttp://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800cdd51.shtml
Please rate if it helps.
VIP Purple
This router has to be updated. 12.4.(20)T1 is really old, in that release T6 is the actual version (that's five rounds of Bugfixing).
If you don't need the features from 12.4.20, I would go for 12.4(15)T17. That release is running on many of my customers routers without problems.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
Hall of Fame Super Gold
Signal = 10,
IOS failure or bug.
Hi Leo,
Only if the adress is out of the valid memory range. We need to check if the address 0x813B is in a list of valid addresses from "show region".
In case the address is valid  - it is HW issue.
Kind Regards,
Ivan
Kind Regards, Ivan Shirshin **Please grade this post if you find it useful.
C'mon, Ivan!  Y'know I don't have the tools to do this ... Hmmmm ... will "test crash" replicate this perhaps?
LOL
For that one you need just to compare the address and start/end numbers :-)
Router#show region
Region Manager:
     Start         End     Size(b)  Class  Media  Name
0x00000000  0x007FFFFF     8388608  Local  R/W    main
0x00001000  0x0001922F       98864  IData  R/W    main:data
0x00019230  0x000666B3      316548  IBss   R/W    main:bss
0x000666B4  0x007FEFFF     7965004  Local  R/W    main:heap
0x007FF000  0x007FFFFF        4096  Local  R/W    main:flhlog
0x00800000  0x009FFFFF     2097152  Iomem  R/W    iomem
0x03000000  0x037FFFFF     8388608  Flash  R/O    flash
0x0304033C  0x037A7D3F     7764484  IText  R/O    flash:text
Btw, two "test crash" options for Bus Error speak about this HW kind of issues - parity in main or I/O memory:
Ciscozine#test crash
Type the number for the selected crash:
2  (crash router) Bus Error, due to parity error in Main memory 3  (crash router) Bus Error, due to parity error in I/O memory
Kind Regards,
Ivan Shirshin
663
