11-03-2011 05:12 AM - edited 03-04-2019 02:08 PM
I have a Cisco 2911 router with 4 T1 connections. Two are set as a multilink and the other two are for two other locations. The router will run fine, but after a month I cannot ping the gigabit ethernet 0/0 interface. I would have to manually reboot the router to get it to respond again. Before I noticed a lot of interface discards which would shutdown the 2911 and a manual reboot would be needed, but for this time it isn't the case. Where would I start with this the memory and cpu usage are fine.
Here is the config:
Current configuration : 2905 bytes
version 15.0
service password-encryption
hostname 2911
boot-start-marker
boot-end-marker
card type t1 0 0
card type t1 0 1
no aaa new-model
clock timezone gmt -5
clock summer-time cdt recurring
no network-clock-participate wic 0
no network-clock-participate wic 1
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO2911/K9 sn FTX1513ALLS
controller T1 0/0/0 -- Multilink
cablelength long 0db
channel-group 0 timeslots 1-24
controller T1 0/0/1 -- Multilink
clock source internal
controller T1 0/1/0
channel-group 3 timeslots 1-24
controller T1 0/1/1
channel-group 2 timeslots 1-24
buffers middle permanent 200
buffers middle max-free 230
buffers middle min-free 50
buffers big permanent 75
buffers big max-free 200
buffers big min-free 15
buffers verybig permanent 20
buffers verybig max-free 20
buffers tune automatic
interface Multilink1
ip address 192.168.200.1 255.255.255.252
ip flow ingress
ip flow egress
load-interval 30
ppp multilink
ppp multilink group 1
ppp multilink fragment disable
no cdp enable
hold-queue 4000 out
interface GigabitEthernet0/0
ip address 10.10.99.1 255.255.255.0
ip flow ingress
ip flow egress
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:0
no ip address
encapsulation ppp
ppp multilink
no fair-queue
hold-queue 40 out
interface Serial0/0/1:0
no ip address
encapsulation ppp
ppp multilink
no fair-queue
hold-queue 40 out
interface Serial0/1/0:3
ip address 192.168.1.2 255.255.255.0
ip flow ingress
ip flow egress
load-interval 60
no fair-queue
hold-queue 4000 out
interface Serial0/1/1:2
ip address 192.168.8.2 255.255.255.0
ip flow ingress
ip flow egress
load-interval 30
no fair-queue
hold-queue 4000 out
ip forward-protocol nd
no ip http server
no ip http secure-server
ip flow-cache timeout active 1
ip flow-export source GigabitEthernet0/0
ip flow-export version 5
ip flow-export destination 10.10.14.49 2055
ip route 0.0.0.0 0.0.0.0 10.10.99.10
ip route 10.10.17.0 255.255.255.0 192.168.1.1
ip route 10.10.25.0 255.255.255.0 192.168.8.1
ip route 10.10.94.0 255.255.254.0 192.168.200.2
snmp-server community ipBalance RO
snmp-server community SolarWinds RO
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
session-timeout 60
privilege level 15
password 7
logging synchronous
login
transport input telnet
scheduler allocate 20000 1000
end
11-03-2011 05:23 AM
First thing, to reduce the discards on the interface, please hard code the interface to whatever you want like 100/full-duplex
or 1000/full duplex if you are connecting with ethernet.
secondly, what IOS are you using. I guess there might be some memory leaks or some BUGs associated. Try to check in cisco website for bug toolkit. I heard that the new IOS's seem to have plenty of issues
thirdly i would suggest you send your syslogs to a syslog server. It would give you more idea of whats going on before the router dies.
Hope this helps
Kishore
11-03-2011 05:46 AM
Kishore,
I just hard coded the gigabit 0/0 to 1000 full duplex. The interface errors were occuring on the serial interfaces due to someone doing videoconferencing and trying to use more than 1.5Mbps over the T1. Once they throttled down the video conferencing equipment, the errors seemed to go away.
IOS is
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M4, RELEASE SOFTWARE (fc1)
For syslogs I enabled:
logging trap notifications
logging IP of syslog server
service timestamps log datetime msec localtime show-timezone year
06-23-2014 04:36 AM
We have recently installed some 2911's, after a few weeks we cant log into the consol, it comes up with a memory issue. THE IOS is version 15.2-4m3
It has serial cards and a voice card/ UC software
Any advice, this box failing is giving us big probelms
