Cisco 2921 WAN Failover
Have Cisco 2921 Routers and want to configure ISP failover from 0/0 to 0/1 without BGP. What is the best way to do this?
1 REPLY
What type of connection? You
What type of connection? You can use floating static routes to back up the primary ISP, or you could use a backup interface for the secondary ISP. You'd simply use a default route, but you'd only go over one link as long as it was up. You could use sla and tracking to make sure the ISP was up on the other side, and should the tracking go down, bring the other static route into the table to go over the backup route....
HTH,
John
HTH, John *** Please rate all useful posts ***
72
