03-19-2008 11:15 AM - edited 03-03-2019 09:12 PM
Pls tell how to upload .tar file to flash and ativate boot image?
And what form following IOS I can use to restore booting of the switch. In my 2950 flash and nvram are erased with command:
"erase nvram" and "erase flash".
C2950 EI AND SI IOS CRYPTO IMAGE
c2950-i6k2l2q4-mz.121-22.EA11.bin
C2950 EI AND SI IOS CRYPTO AND WEB BASED DEVICE MANAGER
c2950-i6k2l2q4-tar.121-22.EA11.tar
C2950 EI AND SI IOS IMAGE
c2950-i6q4l2-mz.121-22.EA11.bin
C2950 EI AND SI IOS IMAGE AND WEB BASED DEVICE MANAGER
c2950-i6q4l2-tar.121-22.EA11.tar
03-20-2008 12:28 AM
While starting I see:
C2950 Boot Loader (C2950-HBOOT-M) Version 12.1(11r)EA1, RELEASE SOFTWARE (fc1)
Compiled Mon 22-Jul-02 17:18 by antonino
WS-C2950T-24 starting...
Base ethernet MAC Address: 00:15:63:d7:3e:80
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 0 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 1024
flashfs[0]: Bytes available: 7740416
flashfs[0]: flashfs fsck took 4 seconds.
...done initializing flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading ""...: permission denied
Error loading ""
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
switch:
switch:
03-20-2008 03:58 PM
