11-16-2007 03:10 AM - edited 03-03-2019 07:34 PM
Hi All,
We just upgraded a 3640 Router Flash Memory from 8+8 MB to 16+16 MB. After the Upgrade we are trying to upload a Latest IOS(which is 21 MB) and we get the following error.
rommon 7 > xmodem -c c3640-jk9o3s-mz.123-24.bin
Do not start the sending program yet...
device does not contain a valid magic number
dir: cannot open device "flash:"
WARNING: All existing data in flash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n [n]: y
get_man_dev: Unknown device - probably NOT formatted.
Ready to receive file c3640-jk9o3s-mz.123-24.bin ...
BB0
ERR:Image size exceeds free flash space
Someone throw some light on how to get this resolved.
Thanks in Advance,
11-16-2007 03:16 AM
You need to format flash first.
The better way out is to use "-r" switch.
This will boot the router using IOS loaded in RAM. Then ypu can format and upload the IOS. This would be fast in compared to xmodem.
Pls do comeback if u face problem.
JD
11-16-2007 04:02 AM
Thanks for the immediate response. I tried but with no luck. Please find the details below.
rommon 8 > boot -r
NOTE: Boot options -r, -n, and -a are for debugging with GDB.
boot: cannot open "flash:"
boot: cannot determine first file name on device "flash:"
Thanks in Advance
11-16-2007 09:34 AM
No. You got it wrong.
Its "xmodem -r 36xx.bin"
