Webcast-Catalyst9k
Cisco 3640, NM-4T1-IMA intermittent no connectivity issue
HELP!!! I have a customer with a Cisco 3640 router and an NM-4T1-IMA (currently 1 T-1). Every so often there connection to the WAN just dies and the router requires a reload to regain connectivity. Local routing is unaffected. This problem happens every couple of weeks, days, or may not happen for a year or more but when it does it is a very bad thing. The ISO image is c3640-ik9s-mz.123-14.t3.bin. The router has a full 128/32 flash/mem.
The log output is as follows:
2006-10-30 13:48:57 Local7.Notice 192.168.1.254 4617: Oct 30 13:41:23: %IMA-5-ACTIVE_LINK_CHANGE: IMA Group ATM3/IMA1 now has 1 active links, active link bitmap is 0x1.
2006-10-30 13:49:07 Local7.Error 192.168.1.254 4618: Oct 30 13:41:33: %LINK-3-UPDOWN: Interface ATM3/0, changed state to down
2006-10-30 13:49:07 Local7.Error 192.168.1.254 4619: Oct 30 13:41:33: %LINK-3-UPDOWN: Interface ATM3/IMA1, changed state to down
2006-10-30 13:49:07 Local7.Notice 192.168.1.254 4620: Oct 30 13:41:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM3/0, changed state to down
2006-10-30 13:49:08 Local7.Notice 192.168.1.254 4621: Oct 30 13:41:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM3/IMA1, changed state to down
The T-1 is fine. A 24 hour monitor was clean. I also happen to be the telephone company T-1 tech.
The router interface is as follows:
interface ATM3/0
description Physical Interface for 60.XXXX.XXXXX..XX - Backbone T1
no ip address
no atm ilmi-keepalive
ima-group 1
no scrambling-payload
interface ATM3/1
description **** NOT IN USE ****
no ip address
shutdown
interface ATM3/2
no ip address
shutdown
interface ATM3/3
no ip address
shutdown
interface ATM3/IMA1
description Primary Connector Interface for Sub-IF
no ip address
interface ATM3/IMA1.1 point-to-point
description Connector Interface for 60.XXXX.XXXXX..XX - Backbone T1
ip address XX.XXX.XXX.XX 255.255.255.XXX
ip verify unicast reverse-path
no ip unreachables
ip accounting output-packets
ip nat outside
ip virtual-reassembly
atm pvc X 0 XXX aal5snap
Some one please help. Any suggestions would be great. Let me know if I can provide any additional information.
Silver
Re: Cisco 3640, NM-4T1-IMA intermittent no connectivity issue
Silver
Hi Shawn ,
Can you paste the output of "" sh ima int atm3/ima1.
Satish
Silver
Hi ,
Troubleshooting ATM IMA Links on Cisco 2600 and 3600 Routers
http://www.cisco.com/warp/customer/121/ima_tshoot.html
satish
142
