Community Member
Cisco 3640 SDM Installation error
I am using Cisco 3640 /w IOS image 12.4(5) mainline. I tried to install Cisco Router Security Device Manager, SDM but failed. I did research on CCO and follow instructions to enable SDM installation but still got error as follow.
"rcp is denied through connected interface". Any clues?
1 REPLY
Re: Cisco 3640 SDM Installation error
Did you install the common.tar files. I would recommend to install it again manually with all the related files.
Here are the steps:
Step 1: Upload the following files to the router's flash:
sdm.tar
common.tar
home.shtml
home.tar
sdmconfig-modelnum.cfg
Router#copy tftp: flash:
Address or name of remote host []? 10.10.10.1
Source filename []? sdm.tar
Destination filename [sdm.tar]?
%Warning:There is a file already existing with this name
Do you want to over write? [confirm]
Step 2: Enable the router's HTTP/HTTPS server, using the following Cisco IOS commands:
Router(config)# ip http server
Router(config)# ip http secure-server
Router(config)# ip http authentication local
If the router uses an IPSec Cisco IOS image, the HTTPS server is enabled. Otherwise only
the HTTP server is enabled.
Step 4 Create a user account with privilege level 15 (enable privileges).
Router(config)# username privilege 15 password 0
Replace and with the username and password that you want
to configure.
Step 5 Configure Telnet for local login and privilege level 15:
Router(config)# line vty 0 4
Router(config-line)# privilege level 15
Router(config-line)# login local
Router(config-line)# transport input telnet
Router(config-line)# exit
HTH, Please rate if it does.
-amit singh
505
