cisco 3640 with 2 ISP & route-map load balancing
I'm trying to setup 3640 router with 2 ISP's. I can't have BGP because one ISP is comcast running on simple SMC modem/router/firewall but is it perfectly fine to have "route-map " type balancing. I'd like to have 5 IP addresses to use T1 and the rest comcast. (in my config only 1 is set -192.168.30.151)
What am I missing in my current config:
version 12.4
service timestamps debug uptime
service timestamps log uptime
hostname cisco3640
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
enable secret 5 $1$rpH4$/jrOUBf232342342b.
enable password 123xxxxxxxxx321
no aaa new-model
memory-size iomem 10
ip cef
ip name-server 4.2.2.2
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.30.1 192.168.30.150
ip dhcp pool 1
   network 192.168.30.0 255.255.255.0
   default-router 192.168.30.1
   dns-server 4.2.2.2 4.2.2.5
   domain-name mylocaldomain.com
   lease 1 1
interface FastEthernet0/0
description connected to localLAN
ip address 192.168.30.1 255.255.255.0
ip nat inside
ip virtual-reassembly
speed auto
half-duplex
interface Ethernet1/0
description T1 internet
ip address 69.x.x.98 255.255.255.240
ip nat outside
full-duplex
interface TokenRing1/0
no ip address
shutdown
ring-speed 16
interface Ethernet2/0
description COMCAST internet
ip address 192.168.26.1 255.255.255.0
ip nat outside
half-duplex
router rip
version 2
passive-interface Ethernet2/0
no auto-summary
ip http server
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.26.254
ip route 0.0.0.0 0.0.0.0 69.x.x.97
ip nat inside source route-map ISP-T1 interface Ethernet1/0 overload
ip nat inside source route-map ISP-comcast interface Ethernet2/0 overload
access-list 10 permit 192.168.30.0 0.0.0.255
access-list 11 permit 192.168.30.151
route-map ISP-comcast permit 10
match ip address 10
match interface Ethernet2/0
route-map ISP-T1 permit 11
match ip address 11
match interface Ethernet1/0
control-plane
line con 0
line aux 0
line vty 0 4
password 123xxxxxxx321
login
end
Re: cisco 3640 with 2 ISP & route-map load balancing
I'm no expert in this but it looks like your route map statements have one too many match statements.  You are saying "Add the packet route route-map ISP-comcast if it matches access list 10 AND is comes in E2/0".  Try removing the second match statement.
Silver
In the given acl
access-list 10 permit 192.168.30.0 0.0.0.255 the ip .151 is also permitted. Could you add deny first for .151 in acl 10 then permit 192.168.30.0 0.0.0.255
regards
Shivlu Jain
http://www.mplsvpn.info
502
