JB
Community Member
Cisco 3700 module change
I have a Cisco 3700 that has 4 fast ethernet modules. One of them is faulty and needs replacing. I have the new part but need to know what the procedure is for replacement. Ie back set up etc Please can someone advise
Hall of Fame Super Bronze
Re: Cisco 3700 module change
John,
If the replacement part is identical, shut down the router and replace. The config shouldn't change. However, I always recommend backing up the config.
Just do a 'show run' and copy and paste to notepad. If something changed, you have the original config in your workstation.
___
Please rate helpful posts.
