Cisco 3725 CPU Over Load
This is very strange to me that router is using 24% cpu while sh proc does not show any process the one using/eating this one.
show proc cpu ouyput..
Router# sh proc cpu | exc 0.00%__0.00%__0.00%
CPU utilization for five seconds: 25%/24%; one minute: 25%; five minutes: 24%
PID Runtime(ms) Invoked uSecs
5Sec 1Min 5Min TTY Process
2 1816 1261734 1 0.00% 0.02% 0.00% 0 Load Meter
5 3552392 645526 5503 0.00% 0.05% 0.05% 0 Check heaps
47 1976700 106531 18555 0.32% 0.03% 0.00% 0 Per-minute Jobs
86 1342800 9707593 138 0.08% 0.01% 0.00% 0 IP Input
128 1668 12617805 0 0.00% 0.02% 0.00% 0 DHCPD Receive
140 2384 63082727 0 0.08% 0.02% 0.00% 0 RBSCP Background
203 738464 28841181 25 0.08% 0.01% 0.00% 0 BGP Router
234 11756 197143943 0 0.08% 0.07% 0.08% 0 PPP manager
235 7372 197150221 0 0.08% 0.04% 0.06% 0 PPP Events
246 897856 420780 2133 0.16% 0.01% 0.00% 0 BGP Scanner
247 804 60870 13 0.00% 0.20% 0.09% 162 Virtual Exec
248 42680 2105112 20 0.00% 0.00% 0.31% 163 Virtual Exec
Router: 3725
IOS: 12.4 (3b)
If you look into the output; one can see that cpu usage is above 24% but there is no process taking this or even we combine all the process using cpu, it is still less than 1 or 2 %....
What could be wrong? How can I check which process is using this amount of cpu. :)
Hall of Fame Super Gold
Re: Cisco 3725 CPU Over Load
if you do "show proc cpu sorted", it should show you the processes in order of CPU percentage taken. If still you don't see a process accounting for the total, I suggest you cotnact the TAC for further investigation.
Hope this helps, please rate post if it does
Router# show proc cpu sorted
CPU utilization for five seconds: 27%/26%; one minute: 26%; five minutes: 26%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
5 3554988 645914 5503 0.24% 0.07% 0.06% 0 Check heaps
2 1816 1262492 1 0.08% 0.02% 0.00% 0 Load Meter
234 11756 197262402 0 0.08% 0.07% 0.08% 0 PPP manager
247 384 48309 7 0.08% 0.02% 0.00% 162 Virtual Exec
3 0 1 0 0.00% 0.00% 0.00% 0 chkpt message ha
6 1864 6263 297 0.00% 0.00% 0.00% 0 Pool Manager
7 0 2 0 0.00% 0.00% 0.00% 0 Timers
You see the result is same.. I still can't see the process taking this amount of CPU... What could be wrong? If it's not a bug in IOS.
Seems like a ghost process is using CPU without showing in the list. Certainly could be a bug. I suggest you to upgrade to latest maintenance of 12.4 that is (13b) as of today and if the problem persist, seek advice from the TAC.
Weired, i think that i've heard once that it has a special math to be done, and the original poster output is normal, as i get the same on one of my routers:
Router#sh processes cpu sorted | e 0.00%__0.00%__0.00%
CPU utilization for five seconds: 38%/36%; one minute: 36%; five minutes: 36%
4 76037508 6245904 12174 0.95% 0.13% 0.11% 0 Check heaps
111 604 932 648 0.63% 0.22% 0.08% 2 Virtual Exec
54 364648608 404073320 902 0.31% 0.29% 0.27% 0 IP Input
38 150057840 382240206 392 0.23% 0.28% 0.25% 0 ATM OAM Input
31 177433360 50006150 3548 0.15% 0.21% 0.23% 0 Per-Second Jobs
150 36713600 141562328 259 0.15% 0.06% 0.04% 0 BGP Router
152 16506796 21491286 768 0.07% 0.00% 0.00% 0 BGP I/O
37 4395220 6692061 656 0.00% 0.01% 0.00% 0 ATM ARP INPUT
28 23629696 5573067 4239 0.00% 0.01% 0.01% 0 Net Background
43 46479756 75497990 615 0.00% 0.06% 0.07% 0 CEF process
46 25796112 943220 27349 0.00% 0.02% 0.00% 0 Per-minute Jobs
73 55550860 1083328 51277 0.00% 0.10% 0.06% 0 IP Background
132 8563560 43976503 194 0.00% 0.01% 0.00% 0 TDP Hello
135 11006636 29476947 373 0.00% 0.03% 0.00% 0 ISIS Upd
138 27511900 52177642 527 0.00% 0.01% 0.00% 0 PDU DISPATCHER
139 171455016 53086972 3229 0.00% 0.02% 0.08% 0 SNMP ENGINE
153 376285784 5193129 72458 0.00% 0.57% 0.58% 0 BGP Scanner
157 8929208 6883160 1297 0.00% 0.02% 0.00% 0 RIP Router
158 2462152 2846367 865 0.00% 0.01% 0.00% 0 RIP Send
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_tech_note09186a00800a65d0.shtml#showproccpu
I think that i'll try to dig further to remember my old info.
BR,
Mohammed Mahmoud.
Ok, AFAIR the first number in the "sh processes cpu" indicates the total CPU utilization, while the second number indicates the percent of CPU time spent at the interrupt level, the difference between these 2 numbers should be summation of the time taken by each process, and thus your output is normal.
HTH,
Mohammed Mahmoud.
Correct, in my previous answer I must have had the brain switched off.
So you should check amount of traffic switched and if it is significant that indicates the the router is normal and healty.
389
