CISCO 3745 error
hi
The following error displayed in console.Please help me to boot this router
error:
System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2002 by cisco Systems, Inc.
c3745 processor with 196608 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
rommon 1 >
thanks in advance
Re: CISCO 3745 error
Its not an error , your device is in rommon mode.Please find the below link to recover the device from rommon mode:-
http://www.cisco.com/en/US/products/hw/routers/ps282/products_tech_note09186a008075fd05.shtml#rmon11
or
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a008009429f.shtml
Hope this helps.
Sum
hi
the following messages displayed
program load complete, entry point: 0x80008000, size: 0x6af738
Error : compressed image checksum is incorrect 0x87CF42D9
Expected a checksum of 0x42EF42D9
*** System received a Software forced crash ***
signal= 0x17, code= 0x5, context= 0x0
PC = 0x800080d4, Cause = 0x20, Status Reg = 0x3041a803
rommon 1 >
Hall of Fame Super Gold
Try realoding the image or boot straight without writing to flash, using the option in tftpdnld.
After reloading new image the follwing error displayed.
program load complete, entry point: 0x80008000, size: 0x11605dc
*** TLB (Load/Fetch) Exception ***
Access address = 0x7074e
PC = 0x8040ad90, Cause = 0x8, Status Reg = 0x3041a803
monitor: command "boot" aborted due to exception
rommon 1 >
Regs
S.Mohan
Were you trying to upgrade the memory before this error message started appearing?
No.Nothing changed in hardware.i am reloading image through rommon mode with xmodem command.
regs
s.mohan
Silver
Hi ,
Another simple way to load new image is first load the image in RAM using xmodem command ie ..
xmodem filename -r
Router boots with the image stored in DRAM.
After that make sure that router is not reloaded until you load the image to flash using tftp server.
Once you load the image using tftp reload the router and make sure that config-reg value must be 0x2102.
If you face the same problem after following the above procedure check the flash once.
Hope this helps you.
Satish
462
