Webcast-Catalyst9k
Cisco 3745 - Link upgrade from DS3 to OC3
Please, we will be upgrading the link from DS3 to OC3.
I would just want to verify if Cisco 3745 could be installed with ATM enhanced PA OC3 card?
Cisco Hardware
cisco 3745 (R7000) processor (revision 0.0) with 115712K/15360K bytes of memory.
Processor board ID
R7000 CPU at 350Mhz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
4 FastEthernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
1 ATM network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of non-volatile configuration memory.
31744K bytes of ATA System CompactFlash (Read/Write)
Thanks!
Gil
1 REPLY
Re: Cisco 3745 - Link upgrade from DS3 to OC3
The 3745 will not take the PA's (PA is for the 7200 platform).
The part number for the OC3 Network Module (NM) is NM-1A-OC3xx (where xx is the optic type multimode/single mode, etc.).
Under Network Modules
http://www.cisco.com/en/US/prod/collateral/routers/ps282/product_data_sheet09186a008009203f.html
HTH,
jerry
491
