Community Member
Cisco 3750 ether channel configuration between Cisco and nortel
I have cisco3750 switch i am trying to make ether channel on that switch below is the configuration i have done on same switch
interface GigabitEthernet1/0/23
switchport mode trunk
speed auto 10 100 1000
duplex full
channel-group 1 mode on
interface GigabitEthernet1/0/24
duplex full
spanning-tree bpdufilter enable
interface Port-channel1
2 ACCEPTED SOLUTIONS
Community Member
to be sure you need to do some tests. LACP is standard IEEE supported on most vendors, you need to check the admin guide of Nortel devices for sure.
Remember that the configuration of ports member of an etherchannel must be identical as speed duplex. vlans etc...
Pier
Silver
Something like this:
duplex full
channel-group 1 mode active
duplex full
spanning-tree bpdufilter enable - I would remove this or put same command on gi 1/0/23
Before everything I would delete intf port-ch 1, and remove commands for it under interfaces and then again put new config with commands which I provided and recreate intf port-ch 1...
BR,
Dragan
HTH, Dragan
Community Member
Pier
Silver
Definitely must use LACP in this kind of environments...
BR,
Dragan
HTH, Dragan
Community Member
hi
Dragan Ili,
can u share the conf temp
Silver
duplex full
duplex full
BR,
Dragan
HTH, Dragan
Community Member
Thanks a lot dragan for helping.
207
