Cisco 3750 not able to telnet from out side
Dear friends,
I have a cisco 3750 switch and i given 2vlans (40, 118). 40 is local and 118 is public.
I given the public ip for vlan 118. now i am able to telnet from same vlan (118 only) but i am not able to ping and telnet as globally.
plz find the config on below and guide me to telnet from out side also.
User Access Verification
Username: cisco
Password:
% Authentication failed.
Username: cisco
Password:
CORE-SW02>en
Password:
CORE-SW02#sh run
Building configuration...
Current configuration : 2826 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname CORE-SW02
enable password 7 052530390
username cisco privilege 15 password 7 0110
aaa new-model
aaa session-id common
switch 1 provision ws-c3750g-12s
system mtu routing 1500
vtp mode transparent
ip subnet-zero
ip routing
no ip domain-lookup
no file verify auto
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
vlan 40,118
interface GigabitEthernet1/0/1
description #### CONNECTED TO LEVEL-0 ###
switchport trunk allowed vlan 40,118
switchport mode trunk
interface GigabitEthernet1/0/2
description ### CONNECTED TO LEVEL0-2 ###
interface GigabitEthernet1/0/3
description ### CONNECTED TO GUESTFLOOR-1 ###
interface GigabitEthernet1/0/4
description ### CONNECTED TO GUESTFLOOR-2 ###
interface GigabitEthernet1/0/5
description ### CONNECTED TO GUESTFLOOR-3 ###
interface GigabitEthernet1/0/6
description ### CONNECTED TO GUESTFLOOR-4 ###
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
description ### UPLINK FROM 2950 ###
interface Vlan1
no ip address
shutdown
interface Vlan40
no ip address
interface Vlan50
no ip address
interface Vlan118
ip address 115.119.xxx.xxx 255.255.255.240
ip default-gateway 115.119.xxx.xxx
ip classless
ip http server
radius-server source-ports 1645-1646
control-plane
line con 0
line vty 0 4
password 7 13111
line vty 5 15
end
CORE-SW02#
Thanks & Regards, Srinivas. N.
Purple
no ip default-gateway 115.119.xxx.xxx
ip route 0.0.0.0 0.0.0.0 115.119.xxx.xxx
Regards.
Alain
Re: Cisco 3750 not able to telnet from out side
Actually the ip default-gateway does not need to be deleted.
However, you must indeed add a default route as proposed by Alain.
regards,
Leo
Purple
Hi Leo,
I know it need not be deleted but as it is not useful here why leave it?
Regards.
Alain
O but it is very useful!
If you ever need to recover this box via remote and the routing is down, you'll know what it is good for.
This is why many of my operational configs include this setting, especially on L3switches it can be very useful.
regards,
Leo
Purple
Hi Leo,
I hadn't thought about this, good thinking indeed.
Regards.
Alain
543
