CISCO 3845: Error %PSE HW—1—PKT ERROR: preparing paktype of SM CONTROL PACKET
i have an error with my cisco router 3845, during reboot i there one error:
Does the error is complied
Installed image archive
Cisco 3845 (revision 1.0) with 221184K/40960K bytes of memory.
Processor board ID FCZ133670YY
2 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco ips sensor(s), ips monitoring on slot O
DRAM configuration is 64 bits wide with parity enabled.
447K bytes of NVRAM.
250880K bytes of ATA System CompactFlash (Read/Write)
*Feb 11 12:52:17.347: %PSE HW—1—PKT ERROR: preparing paktype of SM CONTROL PACKET
*Feb 11 12:52:44.451: %VPN MW—6—INFO LOC: Crypto engine: onboard O State changed to: Initialized
*Feb 11 12:52:44.455: %VPN MW—6—INFO LOC: Crypto engine: onboard O State changed to: Enabled
*Feb 11 12:52:45.423: %LINK—3—UPDOWN: Interface GigabitEthernetO/O, changed state to up
*Feb 11 12:52:45.423: %LINK—3—UPDOWN: Interface GigabitEthernetO/1, changed state to up
*Feb 11 12:52:45.427: %LINEPROTO—5—UPDOWN: Line protocol on Interface VoIP—NullO, changed state to up
*Feb 11 12:52:45.651: %LINEPROTO—5—UPDOWN: Line protocol on Interface Onboard VPN, changed state to up
*Feb 11 12:52:46.431: %LINEPROTO—5—UPDOWN: Line protocol on Interface GigabitEtherneto/0, changed state to up
*Feb 11 12:52:46.431: %LINEPROTO—5—UPDOWN: Line protocol on Interface GigabitEtherneto/1, changed state to down
*Feb 11 12:52:46.443: %LINEPROTO—5—UPDOWN: Line protocol on Interface IDS—SensorO/O, changed state to up
Thanks for help
Alex
Everyone's tags (1)
1 ACCEPTED SOLUTION
Gold
Here is one possibility:
AIM-IPS-K9:PSE_HW-1-PKT_ERROR' on boot-up
CSCsq24774
Symptom:
When an AIM-IPS-K9 is installed, a router will display the following message as a part of its boot-up process.
%PSE_HW-1-PKT_ERROR: preparing paktype of SM_CONTROL_PACKET
1 REPLY
Gold
CSCsq24774
Symptom:
167
