Webcast-Catalyst9k
Cisco 3845/HSEC
I purchased a Cisco 3845 with HSEC capability. This router should have an on onboard AIM-VPN hardware accelerator card (AIM-VPN/HPII-PLUS). I did a show version and it says there is one VPN module. What command can I execute to verify that the AIM-VPN/HPII-PLUS card is present on the router?
Bronze
Re: Cisco 3845/HSEC
Use the show diag 0 command to obtain hardware information about an installed AIM.
Check out this link
http://www.cisco.com/en/US/products/ps5855/products_installation_guide_chapter09186a00802ccf55.html#wp1008714
and scroll down to the verifying AIM installation section
Re: Cisco 3845/HSEC
I did a show diag 0 on the router and go the attached result. How can verfiy that the module in slot 0 is the AIM-VPN/HPII-PLUS
263
