CISCO 3845 HWIC-2FE IS NOT DETECTED
khader1977
I have cisco 3845 router with 4 HWIC-2FE card none of them is detected the message displayed is
Oct 4 11:21:35.323: %ESWMRVL_FLTMG-5-NOTICE: Notice: FPGA Rev 0x27
*Oct 4 11:21:35.323: fe_mrvl_hw_init : Could not load driver
*Oct 4 11:21:35.323: %ESWMRVL_FLTMG-7-INTERNAL_ERR: Internal error: Unable to intialize the Marvell switch for FE
, -Traceback= 0x60EA608C 0x605D78B4 0x605D74DC 0x60590528 0x60599724 0x6058D23C 0x602CDA14 0x61F18D6C 0x60E9A9A0 0x60E9AC80 0x61EDAC68 0x61EDAC4Chwic_fe_analyze_interface: Couldn't initialize the HWIC FE
*Oct 4 11:21:36.175: %ESWMRVL_FLTMG-5-NOTICE: Notice: FPGA Rev 0x27
*Oct 4 11:21:36.175: fe_mrvl_hw_init : Could not load driver
*Oct 4 11:21:36.175: %ESWMRVL_FLTMG-7-INTERNAL_ERR: Internal error: Unable to intialize the Marvell switch for FE
*Oct 4 11:21:37.027: %ESWMRVL_FLTMG-5-NOTICE: Notice: FPGA Rev 0x27
Router>
Router>
*Oct 4 11:21:37.031: fe_mrvl_hw_init : Could not load driver
*Oct 4 11:21:37.031: %ESWMRVL_FLTMG-7-INTERNAL_ERR: Internal error: Unable to intialize the Marvell switch for FE
*Oct 4 11:21:37.883: %ESWMRVL_FLTMG-5-NOTICE: Notice: FPGA Rev 0x27
*Oct 4 11:21:37.883: fe_mrvl_hw_init : Could not load driver
*Oct 4 11:21:37.883: %ESWMRVL_FLTMG-7-INTERNAL_ERR: Internal error: Unable to intialize the Marvell switch for FE
Please let me know how to resolve this.
7 Replies 7
Edison Ortiz
Card failure - please contact TAC for assistance and request a RMA.
__
Edison.
Dear Editortiz,
Thanks for ur reply.
Jeelany
I upgraded the IOS and it is working fine now.
Can you plz tell me whats the procedure we have to follow..i m also going to do the same change in my router
install solar winds or any freeware tftp server on your laptop
then on the 3845:
conf t
tftp server flash:
end
copy tftp flash
enter ip address of remote tftp server (your laptop)
enter name of the file (the ios name on your laptop, don't forget the .bin extension)
and enjoy it.
before rebooting  specify what the router has to load with the boot command:
conf t
boot system flash:/name_of_copied_ios_  (check the synopsys of this command and point at the right location of your flash memory)
wr
reload
yes
keep in mind you can even use a flash card with a 3845!!!
Alessio
Thanks dude..but the thing is i am going to insert HWIC card to my 3845 router..can u plz tell me d procedure
Hi Kumar,
if you refer to the physical procedures nothing is beter than the documentation that cisco provides with the card. I don't remember if it is hot-swap (inserting the card without switching off the router) but it is very very very worth to check on that documenation.
by the way, let me give you this link:
http://www.cisco.com/en/US/docs/routers/access/interfaces/ic/hardware/installation/guide/fe_hwic.html
it'll help you. it is very easy everything.
Careful to this... Since you need to reboot the router to load the newer IOS, beter you follow these steps:
1) load the new ios
2)switch off the router and install the card
3) boot the router again
If you did everything correctly it should everything work straight away without further reboot
Alessio
