Cisco 3845 OverTemp Backplane 127c
Router reporting backplane over temp alarm at 127c all other temp are normal.
Hall of Fame Super Gold
Re: Cisco 3845 OverTemp Backplane 127c
Check and make sure your fans are working using the command "sh env".
All fans are ok, The fan is running high but that will be due over temp alarm. The inlet & chassis temps are okay, so not sure if this a bug in the IOS or a faulty sensor.
This has occurred on two routers in different locations with the same IOS both occurred shortly after a reload and recording the same 127c temp.
294
