08-03-2014 06:41 PM - edited 03-04-2019 11:28 PM
hi all,
got an alarm on one of our core 3945 router.
is this for RMA? is for the 1x fan or whole chassis?
Aug 4 01:06:43.262 UTC: %ENVMON-4-ONE_FAN_LOW_RPM: Warning: Fan 2 is running at low RPM. Rotation speed is now high for all other fans. Fan Tray replacement is recommended.
Aug 4 01:07:13.297 UTC: %ENVMON-1-CPU_WARNING_OVERTEMP: Warning: CPU temperature 105C exceeds threshold 95C. Please resolve system cooling immediately to prevent system damage
sh envi
SYSTEM POWER SUPPLY STATUS
Internal Power Supply 1 Type: AC
Internal Power Supply 1 12V Output Status: Normal
Internal Power Supply 2 Type: Absent <<<
SYSTEM FAN STATUS
Fan Rotation Alert: Total 1 Fan Low RPM <<<
Fan 1 OK, Maximum speed setting
Fan 2 Low RPM <<<
Fan 3 OK, Maximum speed setting
Fan 4 OK, Maximum speed setting
Fan 5 OK, Maximum speed setting
SYSTEM TEMPERATURE STATUS
Intake Left temperature: 36 Celsius, Normal
Intake Right temperature: 29 Celsius, Normal
Exhaust Right temperature: 44 Celsius, Normal
Exhaust Left temperature: 49 Celsius, Normal
CPU temperature: 106 Celsius, Over-Temperature <<<
Power Supply Unit 1 temperature: 40 Celsius, Normal
REAL TIME CLOCK BATTERY STATUS
Battery OK (checked at power up)
SYSTEM POWER
Motherboard Components Power consumption = 79.0 W
Total System Power consumption is: 79.0 W
Environmental information last updated 00:00:07 ago
also, i noticed the confreg is 0xF.
can i change this to 0x2102 without causing disruption or do i need to reload?
chnology Package License Information for Module:'c3900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc None None None
data datak9 Permanent datak9
Configuration register is 0xF
Solved! Go to Solution.
08-04-2014 01:33 AM
Forgot to mention, pre.
You open a TAC Case on the serial number of your appliance. Cisco will then send you the replacement part.
Show them the output to the command "sh env status" and this is more than enough.
08-03-2014 08:20 PM
You will need to open a TAC Case to RMA the fan assembly. When the fan assembly arrives, it will also include (hopefully) a detailed instruction on how to replace it.
08-03-2014 08:32 PM
leo,
salamat pre!
have you previously encountered this issue? are you able to share the instructions for fan installation?
i also noticed PSU2 is not detected. 'asbent' on show envi and blank on show inv.
is this for RMA as well? do these envi logs related to the PSU issue?
08-03-2014 08:37 PM
Pre!
I have replaced faulty fan assemblies with 2800. The ISR G1/G2 are suppose to have modular parts so you don't have to RMA the complete unit (higher costs to Cisco).
08-04-2014 01:33 AM
12-12-2017 11:36 AM
HI ..
I got an alarm on one of our 3945 router. So please let me know what is the replacement part fan try or whole chassis ....?
(Note:- have using to CISCO3945-CHASSIS)
08-03-2014 11:44 PM
Hi John,
As per the error you ned to replace the complete Fan tray i dout about single Fan replacemnet below are the part number whihc you can order depending on you Devices,
3900-FANASSY= (Cisco 3925/3945 Fan Assembly (Bezel included))
3900-FANASSY-NEBS= Cisco 3925/3945 Fan Assembly for NEBS (w/3900-FANFLTR-NEBS)
For changing config register to 0x2102 won't have any impact on production but it will require reload for applying the new config register vlaue.
Hope this answers your query
