02-06-2012 03:45 PM - edited 03-04-2019 03:09 PM
Hi, in Cisco 3945 product sheet its written "
Does that mean i can use 3 Gigabit Interface for sure , without buying any additional SFP cards?
and if i buy 2 SFP Cards with Copper output, i have total 5 Gig interfaces?
and can i use 1 SFP Port for Copper output and 1 for Fiber out put?
02-06-2012 03:49 PM
Yes, that is correct.
No. The two ports are "dual-personality". Meaning you can either use copper OR SFP. Not both.
02-06-2012 04:02 PM
According to this URL,
i guess i can only use 1 builtin Gigabit for sure.
and then to use 2 more Gigabit, i will need to buy either 2 SFP Ports module for Copper Ethernet output or 2 SFP Port module for Fiber output.
Means Total 3 Ports i can use and not 5.
am i correct?
02-06-2012 04:19 PM
Hmmmm ... What are you trying to achieve and what BANDWIDTH are you trying to push?
02-06-2012 04:31 PM
i have attached an image with original post, if you see that, then Point 7 is confirm builtin Gig Copper port.
Then
about Point 5 and 7, can i use Either both ports in 5 or both ports in 6?
or Point 7 and Point 6 is for sure builtin Gig with Copper output means totsal 3 builtin copper, and in point 5 i have choice to either use both ports as Fiber out or Copper out.
In other word, my bandwidth from carrier is coming on Fiber, so i need 1 fiber out and 2 Copper out for LAN&DMZ, what would be my complete order to be give to my procurement guy
will appreciate your assistance
02-06-2012 04:37 PM
What bandwidth are you expecting from the carrier?
02-06-2012 04:39 PM
200Mbps
02-06-2012 05:09 PM
200Mbps
May not work.
With CEF enabled, the 3945 is rated at 502.78 Mbps. This value is expressed in HALF duplex and with no encryption.
At full duplex, the value drops to 251.39 Mbps. My question is this: Will you be running encryption?
If you are, then the 3945 may not be able to support 200 Mbps from your ISP.
02-07-2012 08:01 AM
Hi leolaohoo,
Thank you for your interest in my query, This Router will be used for Internet + 2 Dozen GRE Tunnels + one IP out of public pool assigned by carrier will be assigned to a Cisco 3030 VPN concentrator , and that concentrator will make 1 Dozen IPSec VPN tunnels ( Thise router will not act as IPSec VPN end point but a pass through), Does those IPSec tunnels put any load on 3945 performance?
02-06-2012 04:45 PM
Hi Ahmad,
Your understanding above is correct. You basically have one fix 10/100/1000 port Gi0/0. The other 2 ports you can use either copper (RJ-45) or fiber (SFP) for a total of 3 1Gig ports.
02-07-2012 08:03 AM
Hi Reza, is it possible to put one rj45 output and one Fiber port output in SFP modules at point 5(diagram reference)?
02-07-2012 04:30 PM
am i correct?
You don't need to buy SFP's UNLESS you want to use fibre.
The two "dual purpose" ports have a copper port & an SFP port - BUT you can only use ONE of the pair - if you plug intot he copper port, then it works. If you plug in an SFP, you CAN'T use the associated copper port.
So yes - you have 3 (three) built-in ports available for use. Two fo them can be *either* copper or SFP based - but you don'd need a copper SFP because there's already a physical copper port available.
The points Leo brought up about throughput are valid - if you're running a 200 Mbps ISP link then a 3945 is going to have issues copeing with full duplex throughput - especially if you're running encryption.
Cheers.
02-08-2012 08:52 AM
Thank you for the explanation Darren, i understand till here.
last Q. if i opt to use 2 SFP ports, can i buy one SFP with Fiberout and one SFP with RJ45 out?
Also, Thank you for brining in my attention the 200Mbps throughput issue, can you recommend any other hardware for this requirement? except 7200?
(Also want to thank you every one who contributed so far )
02-08-2012 02:12 PM
You can, but you're just wasting your money if you do. There's *already* an RJ45 port associated with the dual-purpose port - just use that.
Look, you've got two ports with 4 LOGICAL connections, of which you can only use TWO at a time.
Think of the port as a single port with a media adapter on the end - one outputs 1000BaseT, one outputs 1000baseF. If you put an RJ45 SFP into the SFP port then it's just a waste of the already existing, perfectly working RJ45 port in the convertor.
Get me?
Based on the requirements you've stated above for GRE and IPSec, I'd almost be tempted to use an ASA 5520, but I don't know what routing protocols you want.
You could go to an ASR1001, maybe - 2.5 Gbps throughput in the lowest spec model (license upgradable to 5 Gbps), 4 built in ethernet ports, although I'm not sure if they're SFP ports - if they are, you would need to buy RJ45 SFP's as well as your fibre SFP. I've never actually had one of those to play with, so I'm basing the comment about SFP's on what I can find in pictures on the web. Maybe someone who has one can confirm/deny the SFP situation.
If the ASR1001 does have SFP ports, and can handle your fibre, then you'll have plenty of throughput in the default configuration to do what you want.
Cheers.
02-08-2012 02:54 PM
Oh Man, now i understood, and my confusion is gone.
Actually i was thinking Vertical Grouping of 2 ports SFP+SFP , instead of Horzontal grouping of the ports SFP+RJ45:-s
Thank you very much Darren, and Reza and Leo.
And thankyou For router bottle neck issue as well,i will look for this.
