Community Member
Cisco 4006 CatOS Cisco4006 7.6(17) Question on setting spantree portinstancecost
Dear experts,
Understand this is a question on an old cisco IOS but need some input and advice from you experts.
I have an old cisco switch 4006 running on the old Cisco CatOS 4006 7.6(17)
Currently I need to reload the configuration.
Based on the previous old configuration.
the show run shows the following
"set spantree portinstancecost 2/3 cost -1 mst"
However, when I tried to enter this command in the configuration mode, it rejected
The error message came out "invalid range"
But when I set it to
"set spantree portinstancecost 2/3 cost 1 mst" - the switch accepted the command
- My question, if the CatOS does not allow me to input negative value, how did the show run came out with "-1"?
- Will it work the same way if I put  "1" or I need to do something to make it "-1" on the configuration.
Any advice, feedback is deeply appreciated.
many thanks!
