Cisco 6500 Netflow issue_IOS s72033-advipservicesk9_wan-mz.122-18.SXF17b.bin
Hi All,
I am trying to run netflow on cisco 6500 with IOS s72033-advipservicesk9_wan-mz.122-18.SXF17b. Netflow software we are using is Netflow Analyzer 7 professional. I am getting the router and interfaces in the software but the traffic on the interface on the software is not increasing. Below is the configuration for reference.
mls flow ip full
ip flow-export source Loopback100
ip flow-export version 5
ip flow-export destination "Netflow server" 9996
interface FastEthernet7/18
 description ***TCL-International-MPLS***
 ip address "Omitted"
 ip flow ingress
 speed 100
 duplex full
 service-policy output Mum_MPLS_OUT
end
interface FastEthernet7/20
 description ***MPLS link***
 ip flow ingress
 speed 100
 duplex full
end
INMUMSYMCore1#sh ip flow export
Flow export v5 is enabled for main cache
  Exporting flows to "Netflow server" (9996)
  Exporting using source interface Loopback100
  Version 5 flow records
  3686 flows exported in 2076 udp datagrams
  0 flows failed due to lack of export packet
  0 export packets were sent up to process level
  0 export packets were dropped due to no fib
  0 export packets were dropped due to adjacency issues
  0 export packets were dropped due to fragmentation failures
  0 export packets were dropped due to encapsulation fixup failures
  0 export packets were dropped enqueuing for the RP
  0 export packets were dropped due to IPC rate limiting
  0 export packets were dropped due to Card not being able to export
  • WAN Routing and Switching
46
