Cisco 678 router
I need to know the command to open all ports on my 678 router in order to let my linksys router do the routing. I want to use the vpn capabilities of the linksys router. From what I can tell when I hook both of them up they are NATing back and forth and I can't get out. Does what I am trying to do make sense?
1 REPLY
Silver
Re: Cisco 678 router
The command to open the port
set nat entry add 20 20 tcp
set nat entry add 21 21 tcp
Web/HTTP Server
set nat entry add 80 80 tcp
Secure Web/HTTPS Server
Similarly you have to open which are all the ports u wnat to open
90
