cisco 7204 NPE-G1 GRE tunnel issue
Hi Experts,
I have a 7204 router with NPE -G1 card and have around 200 GRE tunnels with a lot of data input/output from tunnels. Due to amount of high Data or ip input , i am running 60+ % CPU , does having any hardware acceleration cards ( VPN MODULES) thats i can use to speed up GRE tunnels and reduce the load on my CPU ?
PLEASE HELP.
thanks
Manish
  • WAN Routing and Switching
1 ACCEPTED SOLUTION
Gold
Re: cisco 7204 NPE-G1 GRE tunnel issue
Short answer is i think you are stuck.
There is nothing in the 7200 literature to indicate an upgrade path short of replacing the G1 with a G2 and tossing in
the VPN accelerator. (Not sure it would help with GRE) the accelerator mod only works with the NPE G2
I'd look at a router upgrade.
Guys,
ANY THINGS to help me out here .
Manish
Gold
Thank you ....  thats what i thought , but spending company is against our company policy , so I will try to optimize data that needs to be tunneled.
thanks again
manish
Gold
You are welcome. Congrats on squeezing every bit of processing power out of the NPE
About all you can do is look for an archectecture that moves away from GRE. Thats a process beast.
make sure you don't have any convoluted access lists or complicated routing.
Good Luck.
414
