Cisco 7206 VXR NPG2
we are using the cisco 7206 vxr NPG2 router as our core router
in this we are getting high CPU utlization
i have attached the sh proc cpu and interface utlization but as per the router specfication it as to handle 2 million packets per seconds but what our traffic is around 1 lakh packet per seconds which is around 10 % of packet handling but its show 67 %
what could be the reason is it a hardware issue
Hall of Fame Super Gold
Re: Cisco 7206 VXR NPG2
Hi, the 2 Mpps mark is is not a commitment, rater an optimistic marketing promise.
Your router CPU usage is OK for the traffic it's currently handling.
If you want true gigabit performances, get a L3 switch not a CPU based router.
Thanks for your reply
If we are planning for upgrading the router which series router would give double the performance in terms of packet handling since in our case our traffic can increase and we need 5 to 6 Gigabit ethernet port
can any one suggest us which could be best
and also can i buy SUP-720 switch processor and install on the 7206 VXR chasis whether it will work
There are many choices, please contact your local cisco office for design recommendations.
sup-720 can be used only on 6500 and 7600 chassis.
Please remember to rate useful posts with the scrollbox below.
Super Bronze
Next step up in routing performance from a NPE-G2 would be a 7304 with NSE-150, then the ASR series. Depending on your interface and feature needs a L3 switch (as also suggesting by Paolo) might be suitable (especially one of the Metro variants).
7300
http://www.cisco.com/en/US/products/hw/routers/ps352/index.html
ASR
http://www.cisco.com/en/US/products/ps9343/index.html
Switches (especially those under "Metro Ethernet Switches")
http://www.cisco.com/en/US/products/hw/switches/index.html
SUP720 cannot be installed on the 7200 series routers. You need the Catalyst 6500 or the 7600 series for SUP720.
You will have to decide what type of features you would like to run. The 7600 will give you more SP features along with some new BGP features. C6500 is mostly for the Enterprise environment. However, it can be used as the WAN router.
For the 1GE port, if you want to use QoS to shape traffic, you will need to use the SIP/SPA, regular LAN line cards don't support advanced MQC shaping.
HTH,
jerry
Also look at your QOS and ACL configuration as this consumes most cpu utilization. See if you can reduce that configuration. If you can not, ASR may be a good option in your case as it does hardware switching.
As per our requirement we need 5 to 6 Gigabit ethernet port with the Double the packet handling performance of NPG2 in terms of CPU Processor
Main function of our Core router is packet handling between the interface and BGP session to the ISP
so can any one suggest us which platform to proceed and IOS
Super Bronze
"so can any one suggest us which platform"
NPE-G2 is rated at 2 Mpps, the NSE-150 (PXF) at 3.5 Mpps, the ASR ESP-5 at about 4 Mpps. Believe both the latter two platforms will support 5 or 6 gig Ethernet ports. The ASR can also be used with an ESP-10 or ESP-20 which provides about 8 and 10.4 Mpps, respectively.
See my prior post for reference links on both platforms.
I've worked with PXF-based products at cisco. If anybody can demosntrate that an NSE-150 can sustain just 2 Mpps with features offloaded to FXS without crashing, I'll pay beverages to anybody in the forum with at least one star.
PXF is gone forever, thanks heaven.
Super Bronze
Well, I'm not one to guarantee any Cisco product, and would note NSE-100 or -150 are "different", however have experience with a NSE-100 running side by side with a NPE-G1 as Enterprise Internet routers for couple of years now, both processing about the same load, both with full Internet tables from multiple (usually two) ISPs. Have not had any issues with the NSE-100, although neither router normally needs to support a sustained 2 Mpps. Of the two, the NSE-100 shows a slighty lower maximum CPU but a much, much lower average CPU load.
NSE-100
5556555555555665655555555565555555555666666555555655555556565555555555
6533473873626337072237573303338226356022402422457334444213343692512513
100
90
80
70
60 ** * * ** * ****** *** * * * ******** *** * * ** * *
50 **********************************************************************
40 **********************************************************************
30 **********************************************************************
20 **********************************************************************
10 **********************************************************************
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
* = maximum CPU% # = average CPU%
NPE-G1
887677654444445555656666776776654434433445555576776777644344333344444444
236775661967194853144738044418511172436997221809108631190901281464541231
100
90
80 *** ** *
70 ******* * *** **** ********
60 ******** ** * *********** * **********
50 ###*##** *** **********#*#*#**** ***************** * *
40 #######***************#########****** ********########****** * ********
30 ########********###############***********#############*****************
20 ##########**#####################******#################****************
10 ########################################################################
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
Interesting. My bias come from the nse for the 7200, that one you really want to avoid.
Anyway, in this world of today one $1,000 L3 switch does the work of a $100,000 router of few years ago, so in that direction one has to look.
OK, we planned to upgrade the 7206 NPEg2 router with the (Supervisor Engine 2)
Can 7206VXR NPEg1 and NPEg2 chassis support this features
Most of our termination is Gig Ethernet and also we need atleast 8 port Gig ethernet and need to Support HSRP
how i can achieve this we have spare SUP2 with us
can i use that instead of 7206 VXR engine
Hi, you should review the Cisco products before planning.
The 7200 router can only use NPE.
The supervisor engine 2 that you have cannot be used.
But which harware i can use replacing the NPEg2 in terms of Performance ,throughput and no of Gig Ports
and need to support BGP and OSPF
kindly suggets me
If you need full routing, a 7600 with sup 720.
Else even 3560, 3750 do that. But they are not true router.
You should contact yuor local cisco office and they will teach the product offer.
926
