07-09-2010 01:37 AM - edited 03-04-2019 09:00 AM
Hi, Can any one help me to find the maximun number of routing table entries Cisco 7206VXR G2 can handle, if possible, please also provide the reference.
Many thanks.
Solved! Go to Solution.
07-14-2010 12:23 AM
HI,
NPEG2 comes with default RAM of 1GB which is well adequate to hold full internet routes. In our network, NPEG2 are running with 3.5 lakhs of internet routes still around 460MB of Processor memory free. BGP routes alone hold 41MB of memory ("show ip bgp sum" gives you memory hold by BGP).
If you are opting to receive full internet feed, then select IOS which has BGP-Next Hop Tracking feature which reduces significant load on CPU due to BGP scanner.
HTH..
thanks
Arun
Pls rate if it is helpful
07-14-2010 12:23 AM
HI,
HTH..
thanks
Arun
