Webcast-Catalyst9k
Cisco 7606 L2TP problems
Hello.
I need to use L2TP on cisco 7606.
7606#sh module
Mod Ports Card Type                              Model              Serial No.
  1   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAD101501VY
  2   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1014JCAS
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL10489HAD
  6    2  Supervisor Engine 720 (Hot)            WS-SUP720-3B       SAL10499RU5
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0016.9dab.05c6 to 0016.9dab.05dd   2.3   12.2(14r)S5  12.2(33)SRE3 Ok
  2  0016.c812.1ec0 to 0016.c812.1ed7   2.3   12.2(14r)S5  12.2(33)SRE3 Ok
  5  0017.9444.2140 to 0017.9444.2143   5.2   8.4(2)       12.2(33)SRE3 Ok
  6  0017.9444.2390 to 0017.9444.2393   5.2   8.4(2)       12.2(33)SRE3 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC       SAD101800G9  2.0    Ok
  2  Centralized Forwarding Card WS-F6700-CFC       SAD1018006T  2.0    Ok
  5  Policy Feature Card 3       WS-F6K-PFC3B       SAL10489HRF  2.3    Ok
  5  MSFC3 Daughterboard         WS-SUP720          SAL10489G60  2.5    Ok
  6  Policy Feature Card 3       WS-F6K-PFC3B       SAL10499Q8K  2.3    Ok
  6  MSFC3 Daughterboard         WS-SUP720          SAL10499N4P  2.5    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  5  Pass
  6  Pass
When i tried to configure pseudowire-class. It was give warinig message:
% Warning, the interface Gi2/1.20 is not configured to hardware
switch L2TPv3 encap packets. Applying this configuration
will cause software switching of l2tpv3 packets. Please
configure 'mls l2tpv3 reserve slot <slot-num>' on Gi2/1.20
to enable hardware switching.
Command was applied, but L2TP don't work   Anabody help me, what i need to use L2TP?
7606#sh ver
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 26-Jan-11 03:05 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRE3, RELEASE SOFTWARE (fc1)
7606 uptime is 3 days, 17 hours, 48 minutes
Uptime for this control processor is 3 days, 17 hours, 46 minutes
System returned to ROM by reload at 09:52:07 UTC Fri Jul 27 2012 (SP by reload)
System image file is "disk0:c7600s72033-adventerprisek9-mz.122-33.SRE3.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco CISCO7606 (R7000) processor (revision 1.0) with 983008K/65536K bytes of memory.
Processor board ID FOX083203XE
SR71000 CPU at 600MHz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
2 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Everyone's tags (2)
452
