Community Member
Cisco 7941 on CCM 4.1
How do I get the 7941 template added to CCM 4.1?
1 REPLY
Bronze
Re: Cisco 7941 on CCM 4.1
You can change the Softkey Template for a large number of phones by changing it in the Device Pool. To do that, go to "System", "Device Pool", then select the device pool you want to change and you should see a field for the "Softkey Template". After the change you will need to reset all of the devices in that device pool using the "Reset Devices" button at the top of the page. That will drop service for the devices in that pool while they are being reset (typically around 30 seconds.)
111
