02-14-2006 10:41 AM - edited 03-03-2019 11:44 AM
I have trying to run OSPF on a Cisco 801 ISDN Router, but i have an error like this:
router(config)#router ospf 1
Unknown routing protocol
router(config)#
Has the 801 router support for OSPF routing?
The router work with a 12.2 IOS Version.
Solved! Go to Solution.
02-14-2006 11:15 AM
I tried keying in 801 ISDN on Software advisor and it doesnt list OSPF as supported.
Sankar
PS: please remember to rate posts!
Though I do see EIGRP and RIP.
02-14-2006 01:23 PM
as a matter of fact, none of the 800 routers support OSPF. Here is the relevant Q&A from CCO:
Q. Why is it that my Cisco 800 router does not run OSPF?
A. Cisco 800 routers do not support OSPF. However, they do support Routing Information Protocol (RIP) and Enhanced Interior Gateway Routing Protocol (EIGRP).
HTH,
Nethelper
02-14-2006 11:15 AM
Sankar
02-14-2006 11:19 AM
This is likely to be a SOHO or ip-base router.
Not all routing protocols are implemented in these.
The hardware is capable indeed but you need to use a different feature set of the IOS.
To upgrade the router, you will have to buy the feature set upgrade from Cisco and (if required) you should upgrade Flash and/or DRAM.
You are likely to spend less on a new router than this upgrade might cost you.
Leo
02-14-2006 01:23 PM
HTH,
Nethelper
