Community Member
Cisco 819 ( C819(H)G-4G-G-K9 ) 4G Belgium Proximus
Does anyone has a experience with the Cisco 819 in Belgium 4G Proximus?
I need a sollution for a cliënt ho has no fix internet acces only mobile when hé is outside the building.
Outside there is  4G mobile internet access from Proximus ISP (Belgium ) works in the 1800 Mhz band, and the 2600 Mhz later on when
there is no more bandwidth in the 1800 Mhz frequencie. (inside no mobile internet reception ... ). So i can not use an Mi-Wi router..
My Question is wil the Cisco 819 ( C819(H)G-4G-G-K9 ) work with Belgium Operator Proximus ?
I will have to replace the antenne on the routers with a extention cable and outdoor 4G antennas.
Is it sufficient enough to have a router that works in the same frequenties or are there other upper-layer parameters that i have to consider with ?
thanks, for your time and info.
Everyone's tags (3)
238
