Community Member
Cisco 827 & ADSL 2+ ??
Is it possible to do a 827 works in adsl2+ ?. I though just another models as 877 or HWICs may deal a connection in adsl2+ by the G.992.5 ITU.
Re: Cisco 827 & ADSL 2+ ??
The short answer is no, the 827 doesn't support ADSL2+ but the 877 does.
827 ADSL Specifications
Alcatel DynaMiTe ADSL Chipset
?T1.413 ANSI ADSL DMT issue 2
?G.992.1 ITU G.DMT support
?G.992.2 ITU G.Lite support
?G.992.3 ITU G.hs ADSL type negotiation
877 ADSL Specifications
ST-Micro DynaMiTe (formerly Alcatel Micro Electronics) ADSL Chipset (20190)
? T1.413 ANSI ADSL DMT issue 2
? G.992.1 ITU G.DMT support
? G.992.3 ITU G.hs ADSL type negotiation
? G.992.3 (ADSL 2)
? G.992.5 (ADSL2+)
? DSL Forum TR-067
Andrew.
Community Member
Ok,thank you very much, you confirm me what I believed.
don't forget to rate any posts if useful...
A.
1173
