Community Member
Cisco 827 NAT + Access server inside problem
I have a question about a NAT translation to a server in the inside network.
This command is added to de configuration:
ip nat inside source static tcp 10.0.0.50 3389 interface BVI1 3389
Is does not work to connect from the internet to de server on 3389 (RDP). I Have no accesslist on the interface`s.
If i use: sh ip nat translation then i see that inside global is natted to inside local 10.0.0.50:3389
I hope that somebody can helping or can tell my how to debug this problem.
Re: Cisco 827 NAT + Access server inside problem
AFAIK its better to have and static ip on the bvi interface which can be then mapped to the inside address.
I don't think at present you will be able to do RDP without checking out the ip address recieved out on the bvi interface.
If you can get a static ip address assigned to DVI then you can redo the mapping accordingly.
regds
Community Member
If i make a configuration with a static ip-address then i can not ping the gateway of my ISP. With DHCP works everything correct. Is there some reason why static ip don`t work?
Community Member
Thanks for the answher. You can use dynamic ip-adres with NAT translation. I do wrong check. If i check is everything work of the inside network (Does work). If i make a vpn en check the static nat from extern it work fine. Thanks for the tips maby i can use in the feature.
107
