Cisco 831 Source and Destination NAT
I've got a problem dealing with Cisco-NAT.
I've a device which is reachable on the IP 169.254.1.1, with no route set. For some reasons I can't change this setting nor set a route.
I've tried to set up a Cisco 831 with source- and destination-NAT, so the SA gets translated to the 169.254.1.1xx pool and the DA to 169.254.1.1.
The WAN Net of the Cisco is 212.202.254.225/28.
The Cisco is konfigured as follows:
interface Ethernet0
description "LAN"
ip address 169.254.1.254 255.255.0.0
ip nat inside
interface Ethernet1
description "WAN"
ip address 212.202.254.226 255.255.255.240
ip nat outside
ip route 0.0.0.0 0.0.0.0 212.202.254.225
ip nat pool apipa-pool 169.254.1.100 169.254.1.199 netmask 255.255.0.0
ip nat inside source static 169.254.1.1 212.202.254.227
ip nat outside source list 1 pool apipa-pool
access-list 1 permit 195.90.0.0 0.0.255.255
access-list 1 remark "The Network where the clients reside"
When I now start telnet on my Host 195.90.0.241, it just hangs:
xxx@host:~> telnet 212.202.254.227
Trying 212.202.254.227...
On the 169.254.1.1 target device, the debugging looks like the following lines:
01/23/2008-15:04:02:IP-FILTER: I:PROTO 6 (TCP) pkt from 169.254.1.100/1993
01/23/2008-15:04:02:IP-FILTER: to 169.254.1.1/23 accepted, SYN Flag
01/23/2008-15:04:02:IP-FILTER: O:PROTO 6 (TCP) pkt from 169.254.1.1/23
01/23/2008-15:04:02:IP-FILTER: to 169.254.1.100/1993 accepted, SYN/ACK Fls
So the packets are sent correct and get answered.
Debugging on the Cisco 831 looks like this:
fritz#debug ip nat detailed
IP NAT detailed debugging is on
fritz#debug ip packet detail
IP packet debugging is on (detailed)
*Mar 1 11:21:32.019: NAT*: o: tcp (195.90.0.241, 1993) -> (212.202.254.227, 23) [4363]
*Mar 1 11:21:32.019: NAT*: s=195.90.0.241->169.254.1.100, d=212.202.254.227 [4363] <===== OK!
*Mar 1 11:21:32.019: NAT*: s=169.254.1.100, d=212.202.254.227->169.254.1.1 [4363] <===== OK!
*Mar 1 11:21:32.019: NAT: installing alias for address 169.254.1.100
*Mar 1 11:21:32.027: IP: tableid=0, s=169.254.1.1 (Ethernet0), d=169.254.1.100 (Ethernet0), routed via RIB
*Mar 1 11:21:32.031: IP: s=169.254.1.1 (Ethernet0), d=169.254.1.100 (Ethernet0), len 44, rcvd 3
*Mar 1 11:21:32.031: TCP src=23, dst=1993, seq=1298156341, ack=1465516680, win=4096 ACK SYN
*Mar 1 11:21:32.031: IP: tableid=0, s=169.254.1.100 (local), d=169.254.1.1 (Ethernet0), routed via FIB
*Mar 1 11:21:32.035: IP: s=169.254.1.100 (local), d=169.254.1.1 (Ethernet0), len 40, sending
*Mar 1 11:21:32.035: TCP src=1993, dst=23, seq=1465516680, ack=0, win=0 RST
NAT Table:
fritz#show ip nat translations
Pro Inside global Inside local Outside local Outside global
--- --- --- 169.254.1.100 195.90.0.241
--- 212.202.254.227 169.254.1.1 --- ---
I don't know what's wrong. It looks like the answers are not noticed at all on the Cisco router, and don't get routed or NATted. Why not?
IOS is c831-k9o3sy6-mz.124-18.bin.
Any help is greatly appreciated.
Jens
Edison Ortiz
Why do you mean by "no route set" on device 169.254.1.1?
Do you mean you are enable to set a default gateway to 169.254.1.254? Because you need to in order for this device to know that to get to the internet, packets must go to 169.254.1.254.
What you are experiencing is a network with Windows machines and no DHCP available. When a machine boots up and DHCP is unavailable, it automatically addresses itself in the 169.254.0.0/16 subnet.
You need to create a DHCP server on that LAN and change the IP address on the router's LAN interface.
If it's a small LAN, go with a class C address such as 192.168.1.0/24. On the router LAN interface, assign 192.168.1.254/24 and create a DHCP scope for that subnet. Make sure the default gateway on that scope is set to 192.168.1.254.
Change the NAT pool on the router and then you should be able to connect to the internet, it's that simple.
HTH,
__
Edison.
I can't change the IP on that device and I can't add a route or a default gateway on that device.
It is NOT a windows PC. I know that a windows PC uses APIPA adresses too when no DHCP is available, but that's not the point here.
The point is, you don't get routed nor natted from the host.
The host does not have a default gateway.
You are unable to set a default gateway because the IP addressing scheme used does not allowed you to do that.
Did you force the IP address on those devices or were they automatically self-assigned? I'm assuming it's self-assigned due to the inability to set a default gateway.
If you are unable to set the default gateway, how the host is supposed to know to use your router as the exit point of your network?
Makes sense?
__
Edison.
Did you really read my first message?
The cisco has an IP pool in the same 169.254.x.x Subnet and should renumber the SA to this pool, so no gateway is needed.
