Webcast-Catalyst9k
cisco 831
I am unable to access cox internet through cable modem. I cannot upgrade IOS because I can't re-partition webflash to use for upgraded IOS.
version 12.2
no service pad
service timestamps debug uptime
service timestamps log
uptime
service password-encryption
hostname CISCO
no logging buffered
enable secret 5
ip dhcp pool CLIENT
network 10.1.42.0
255.255.255.0
default-router 10.1.42.10
dns-server 68.1.x.x.1.208.30
lease
0 2
ip audit notify log
ip audit po max-events 100
partition flash 2 6 2
interface Ethernet0
description CRWS Generated text. Please do not delete
this:10.1.42.10-255.255.255.0
ip address 10.1.42.10 255.255.255.224
ip nat inside
no cdp
enable
hold-queue 32 in
hold-queue 100 out
interface Ethernet1
ip address *.*.*.*
ip nat outside
no ip mroute-cache
no cdp enable
line con 0
exec-timeout 120 0
no modem enable
stopbits 1
line
aux 0
transport input all
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length
scheduler max-task-time 5000
end
end
1 REPLY
Re: cisco 831
Josh,
Are you saying that you are not able to ping anything on the internet from the router itself or from PC's behind the router.
If you are not able to access the internet from PC's behind the router, then you need to configure NAT on the 831, so your private IP Address will be translated to a routable public ip address.
Sample Configuration:
Inside Interface
Interface Ethernet0
ip nat inside
Outside Interface
Interface Ethernet1
ip nat outside
access-list 100 permit ip 10.1.42.0 0.0.0.255 any
ip nat inside source list 100 interface Ethernet1 overload
The above configuration will allow all 10.1.42.x address to be Port Address Translated to the Ethernet1 Public IP Address.
Now, if you are not able to ping anything on the internet from the router itself, then I would check and make sure that Ethernet1 is configured with a valid IP Address. Is ethernet1 statically configured with a routable IP Address or does it get the ip address via DHCP.
Let me know if it helps.
Arul
190
