Cisco 836 with 16 MBit t-dsl ?
Hi *,
is there a way to use a cisco 836 at a 16 MBit ADSL from t-online ?
ROM: System Bootstrap, Version 12.2(11r)YV3, RELEASE SOFTWARE (fc2)
System image file is "flash:c836-k9o3s8y6-mz.124-17.bin"
when I connect it to the DSL the debug shows:
Feb 21 07:58:12.642: DSL: 1: Modem state = 0x8
Feb 21 07:58:13.050: DSL: Received response: 0x22
Feb 21 07:58:13.050: DSL: Open failed: The ATU-C and ATU-R are not configured fo
r a common mode of operation -- retrying
Feb 21 07:58:13.050: DSL: Modem has open failed for 5 time(s)
Feb 21 07:58:16.050: DSL: Trying to bring up DSL line using Embedded firmware ve
rsion : 4.10.1
Feb 21 07:58:16.050: DSL: Send ADSL_OPEN command.
Feb 21 07:58:16.050: DSL: Using subfunction 0xB
Feb 21 07:58:16.050: LOCAL:Max noise margin for power cutoff 31
Feb 21 07:58:16.050: DSL: Sent command 0x3
Feb 21 07:58:18.550: DSL: 1: Modem state = 0x8
Feb 21 07:58:18.954: DSL: Received response: 0x22
Feb 21 07:58:18.954: DSL: Open failed: The ATU-C and ATU-R are not configured fo
Feb 21 07:58:18.954: DSL: Modem has open failed for 6 time(s)
Feb 21 07:58:21.954: DSL: Trying to bring up DSL line using Embedded firmware ve
rsion : 4.10.1
Feb 21 07:58:21.954: DSL: Send ADSL_OPEN command.
Feb 21 07:58:21.954: DSL: Using subfunction 0xB
Feb 21 07:58:21.954: LOCAL:Max noise margin for power cutoff 31
Feb 21 07:58:21.954: DSL: Sent command 0x3
Feb 21 07:58:24.454: DSL: 1: Modem state = 0x8
Feb 21 07:58:24.858: DSL: Received response: 0x22
Feb 21 07:58:24.862: DSL: Open failed: The ATU-C and ATU-R are not configured fo
Feb 21 07:58:24.862: DSL: Modem has open failed for 7 time(s)
Feb 21 07:58:24.862: DSL: Connection has reached max retries, toggle to other mo
de
Feb 21 07:58:27.862: DSL: SM: [DMTDSL_DO_OPEN -> DMTDSL_INIT]
Feb 21 07:58:28.862: DSL: SM: [DMTDSL_INIT -> DMTDSL_DLOAD_1]
Feb 21 07:58:28.862: DSL: Using Firmware Embedded in IOS
Feb 21 07:58:28.862: DSL: Downloading ASW_init_4_10_1.bin
Feb 21 07:58:28.866: DSL: Downloaded 3 blocks... Finished!
Feb 21 07:58:28.866: DSL: Sent command 0x14
Feb 21 07:58:32.774: DSL: Received response: 0x80
Feb 21 07:58:32.774: DSL: SM: [DMTDSL_DLOAD_1 -> DMTDSL_DLOAD_2]
Feb 21 07:58:32.774: DSL: Downloading ASW_R4_10_1.bin
Feb 21 07:58:32.870: DSL: Downloaded 100 blocks
Feb 21 07:58:32.962: DSL: Downloaded 200 blocks
Feb 21 07:58:33.058: DSL: Downloaded 300 blocks
Feb 21 07:58:33.150: DSL: Downloaded 400 blocks
Feb 21 07:58:33.246: DSL: Downloaded 500 blocks
Feb 21 07:58:33.338: DSL: Downloaded 600 blocks
Feb 21 07:58:33.346: DSL: Downloaded 610 blocks... Finished!
Feb 21 07:58:33.346: DSL: Sent command 0x14
Feb 21 07:58:35.345: changed current state to do open!!
Feb 21 07:58:35.345: DSL: SM: [DMTDSL_DLOAD_2 -> DMTDSL_DO_OPEN]
Feb 21 07:58:35.345: DSL: Trying to bring up DSL line using Embedded firmware ve
rsion : 4.10.1
Feb 21 07:58:35.345: DSL: Send ADSL_OPEN command.
Feb 21 07:58:35.345: DSL: Using subfunction 0x11
Feb 21 07:58:35.345: LOCAL:Max noise margin for power cutoff 31
Feb 21 07:58:35.345: DSL: Sent command 0x6
Feb 21 07:58:37.845: DSL: 1: Modem state = 0x8
Feb 21 07:58:38.257: DSL: Received response: 0x22
Feb 21 07:58:38.257: DSL: Open failed: The ATU-C and ATU-R are not configured fo
1 REPLY
Hall of Fame Super Gold
Re: Cisco 836 with 16 MBit t-dsl ?
You can try ADSL FW 4.10.9 from
ftp://ftp.cisco.com/pub/access/800/
708
