Cisco 837 LAN-to-LAN problem - see config
I have many LAN-to-LAN ADSL Cisco 837's connected to our Cisco 3015 Concentrator. I have just confiured another much the same as the others, but with the new 12.4 IOS. The others use 12.3T. The new router connects to as a LAN-to-LAN fine and VPN tunnel is established, however I can ping the router until a PC on this new VPN router logs on and gets a DHCP address, i can then ping the router and PC. IF the PC's network cable is unglugged from the back of the 837 I can ping the router again, why?? I have the routers config below, must be something simple:
Current configuration : 2991 bytes
! No configuration change since last restart
version 12.4
no service pad
hostname ABCDEFGHI
boot-start-marker
boot-end-marker
no logging buffered
enable password *********
no aaa new-model
resource policy
no ip dhcp use vrf connected
ip dhcp excluded-address 172.19.7.1 172.19.7.10
ip dhcp pool client
network 172.19.7.0 255.255.255.0
default-router 172.19.7.1
dns-server 192.168.1.10 192,168.1.11
lease 0 2
no ip cef
ip inspect name outbound tcp
ip inspect name outbound udp
ip inspect name outbound ftp
ip inspect name outbound http
ip inspect name outbound icmp
username ******** password 0 ********
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key *********** address 10.10.10.1
crypto ipsec transform-set tran_set esp-3des esp-md5-hmac
crypto map tran_set 10 ipsec-isakmp
set peer 10.10.10.1
set transform-set tran_set
match address 101
interface Ethernet0
ip address 172.19.7.1 255.255.255.0
ip inspect outbound in
hold-queue 100 out
interface Ethernet2
no ip address
shutdown
hold-queue 100 out
interface ATM0
no ip address
no ip mroute-cache
atm vc-per-vp 64
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
interface Dialer1
ip address negotiated
ip access-group inbound in
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname name@name.com
ppp chap password 0 ***********
ppp pap sent-username name@name.com password 0 ************
crypto map tran_set
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip access-list extended inbound
permit udp any any eq isakmp
permit esp any any
permit icmp any any
permit udp any any eq ntp
permit tcp *.*.*.* 0.0.0.255 any eq telnet
permit tcp *.*.*.* 0.0.0.255 any eq 22
permit tcp *.*.*.* 0.0.0.255 any eq ftp-data
permit tcp *.*.*.* 0.0.0.255 any eq www
permit tcp *.*.*.* 0.0.0.255 any eq 443
permit ip 192.168.0.0 0.0.255.255 172.19.7.0 0.0.0.255
logging trap warnings
logging 192.168.1.12
access-list 101 permit ip 172.19.7.0 0.0.0.255 any
dialer-list 1 protocol ip permit
snmp-server community ******* RO
snmp-server enable traps tty
snmp-server host 192.168.1.12 RO
control-plane
line con 0
no modem enable
transport output all
line aux 0
line vty 0 4
exec-timeout 0 0
login local
transport input all
scheduler max-task-time 5000
sntp server 158.43.128.33
end
Bronze
Re: Cisco 837 LAN-to-LAN problem - see config
from which IP address to which IP address are you pinging ? And which IP address is being assigned to your Dialer 1 interface ?
Nethelper
As the LAN-to-LAN has been established I'm pinging inside router address 172.19.7.1. from our internal network. I have noticed as soon as a pc is connected and get the next DHCP address 172.19.7.2 I can ping both devices. I hae also noticed the pc and router (from console) can ping the internal network at all times.
Bronze
when you say you are pinging the IP address of the router from your internal network, do you mean the internal network IP 172.19.7.2 ? To be honest I do not clearly understand what you are asking: when your PC gets a DHCP assigned address, what can you NOT ping ?
Nethelper
Right this is proving to be difficult. I will approve from a different angle. This 837 is connected remotely to our Cisco concentrator, it is a LAN-to-LAN. The concentrator and me (head office) are on the same nework. This remote network (837) has one PC connected to it's 4 port hub. Everything works, I can ping the router and PC from the head office, and the PC on the remote network can ping my pc and all server. However as soon as this PC on the remote network is turned off I can no longer ping the remote router. If the PC is turned back on I can.
That makes no real sense - when you say the PC is turned off, I would make sure the remote user is not 'turning off' the router also... you should be able to connect to the public interface anyway to confirm this.
also, I don't really see how this VPN is working at all:-
1. Your crypto ACL matches ALL traffic outbound
2. You don't have a routable destination address for the crypto map (10.10.10.1 is an internal address, but you have no route to it)
3. You appear to have a dynamic IP address on the public interface, so how will the peer establish a connection?
Is this because you have changed the public details for securty?
If so your crypto ACL I think should be:-
access-list 101 permit ip 172.19.7.0 0.0.0.255 192.168.0.0.0.0.255.255
p.
If I understand u correctly you can not ping the remote router internal address?
As I recall these 837 routers have a 4-port hub and an internal int e0. Check when the pc shuts down whether e0 goes down or stays up.
E.
ekiriakos you have hit it on the nail so to speak. I turned off the PC that was on the 4 port hub (back of 837) and this is what is displayed on console:
Feb 20 08:12:47.713: %LINK-3-UPDOWN: Interface Ethernet0, changed state to down
Feb 20 08:12:47.713: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to d
own
Feb 20 08:12:48.713: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0,
Feb 20 08:12:48.713: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEtherne
t2, changed state to down
It does the opposite if the PC is turned back on. Why does the router care what the PC does, the Ethernet0 should stay up.
hope you can advise
I think you may be dealing with an IOS bug - is it possible to downgrade the IOS on this box to the same version as the others? (TFTP from the workstation should be OK)
I have 837's running 12.2/3 and they do not exibit this behaviour.
p.
It may be a bug as suggested. I did a quick search on CCO but can't find anything. Perhaps if you post the exact ver of ios u use, using the sh ver command that may help.
Rgds
E.
Here it is:
Cisco IOS Software, C837 Software (C837-K9O3Y6-M), Version 12.4(5a), RELEASE SOF
TWARE (fc3)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Sat 14-Jan-06 01:43 by alnguyen
ROM: System Bootstrap, Version 12.2(8r)YN, RELEASE SOFTWARE (fc1)
Seems down-grading to 12.3 fix the problem.
263
