Cisco 837 - simple question
I'm a novice and I'm trying to find the version of IOS software my routers are using, below I seem to see version 12.4(4)T4 and 12.3(8r)YI2, should they be the same:
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(4)T4, REL
EASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Thu 03-Aug-06 17:20 by kellythw
ROM: System Bootstrap, Version 12.3(8r)YI2, RELEASE SOFTWARE
gla5g0w uptime is 4 weeks, 1 day, 22 hours, 17 minutes
System image file is "flash:c870-advsecurityk9-mz.124-4.T4.bin"
Re: Cisco 837 - simple question
Hi, whiteford
The softwares you mention reside in different components of this router. One is bootrom, when the routers first power up , it will boot from here.The other is the flash memory, where is the real ios reside in. The software that make your router capable of routing and switching is the ios reside in falsh memory: c870-advsecurityk9-mz.124-4.T4.bin
SSLIN
Thanks, should they be the same?
No, they cannot be the same. Their relationship can be compared to that of BIOS and WinXP for the PC.
SSLIN
Thanks, just have this one, what is the Synched to technology version 12.3(1.6)T all about?
IOS (tm) C837 Software (C837-K9O3Y6-M), Version 12.3(2)XA, EARLY DEPLOYMENT RELE
ASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 08-Aug-03 05:58 by ealyon
Image text-base: 0x800131E8, data-base: 0x80B8F3D8
ROM: System Bootstrap, Version 12.2(8r)YN, RELEASE SOFTWARE (fc1)
ROM: C837 Software (C837-K9O3Y6-M), Version 12.3(2)XA, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)
n3wp0rt uptime is 2 weeks, 4 days, 2 hours, 30 minutes
System restarted at 10:54:42 UTC Mon Jan 29 2007
System image file is "flash:c837-k9o3y6-mz.123-2.XA.bin"
Ok, I've been stumped. I surrender.
To me, the ios is still c837-k9o3y6-mz.123-2.XA.bin, and bootrom is stll 12.2(8r)YN.
I wonder where the line "ROM: C837 Software (C837-K9O3Y6-M), Version 12.3(2)XA, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)" comes from? Maybe some "boot system" command in the config file? I will test this after I go home.
I don't understand what is the "Synched to technology version 12.3(1.6)T"
I kindly ask for help from other netpros.
cheers
SSLIN
147
