01-20-2006 06:15 PM - edited 03-03-2019 11:31 AM
I issued a "erase start" command on my cisco 837 router. After that i'm not able to telnet/hyper terminal to the router now. Will this erase start erase off the image file? What can i do to access back the router? Thks!
01-20-2006 06:23 PM
Telnet will certainly not work. However, you should be able to console into it with hyperterminal.
What happens when you open a hypterterminal session and hit enter a few times ?
Paresh
01-20-2006 07:07 PM
Hi!
It came out with funny characters and symbols...before i did a "erase start", i was able to telnet but the hyper terminal was the same.(with funny charatacters and symbols)
01-21-2006 12:24 AM
make sure your Hyperterminal settings are 9600 (speed), 8 (databits), none (parity), 1 (stopbits), these are actually the defaults, you might want to try different speed settings, see if that makes a difference. You could also try the ´latest´ version of Hyperterminal, which you can download below.
HyperTerminal Private Edition version 6.3
http://www.hilgraeve.com/htpe/index.html
GP
01-21-2006 02:15 AM
Hi! I've tried what you suggested, but it's still the same. Any other suggestion?
Thks!
01-30-2006 07:47 PM
Are you able to try gpauwen's advice. Make sure you restore default settings on your hyperterminal. If not, you might want to try the 115200 bits per second setting...
