cisco 851, NAT
Hello.
I have the next problem:
10.194.0.0/24 is the network behind the 851 router. (LAN)
192.168.224.0/24 the network ahead the 851 (WAN)
I need to translate 10.194.0.0/24 to the IP address of router WAN (192.168.224.x/24; x-number of each cisco 851) if destination is everywhere but 192.168.2.0/24.
And if destination is 192.168.2.0/24 simple routing will appears.
Please, help me to configure the device if it is possible.
Purple
Re: cisco 851, NAT
Try this:
interface ethernet 0
ip nat inside
interface
ip nat outside
ip nat inside source route-map Map1 interface overload
route-map Map1 permit 10
match ip address 101
access-list 101 deny 10.194.0.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 101 permit 10.194.0.0 0.0.0.255 any
Hope that helps - pls rate the post if it does.
Paresh
Re: cisco 851, NAT
Thanks a lot! The problem is solved!
470
