Community Member
cisco 857w wireless and adsl2+ configuration
Hi I'm trying to configure my cisco 857w router for wireless access through an ADSL2+ connection. The following is the configuration, It's not connecting wireless devices or to the ADSL connection. What I'm I missing.
Building configuration...
Current configuration : 2049 bytes
version 12.4
no service pad
service password-encryption
hostname ROUTER
boot-start-marker
boot-end-marker
no aaa new-model
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool my-pool
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   domain-name wr
   dns-server 8.8.8.8
   lease 0 2
ip cef
ip domain name me.local
ip name-server 8.8.8.8
vtp mode transparent
username me password 7 075E740C440812040216030D
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
  pppoe-client dial-pool-number 1
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
encryption mode ciphers tkip
ssid ME-WIFI
    vlan 1
    authentication open
    guest-mode
    wpa-psk ascii 7 07022D434206170218
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1452
bridge-group 1
interface Dialer0
no ip address
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname myispusername
ppp chap password 7 15051E030A253C2126626C7544
ppp pap sent-username myispusername password 7 08365941071612121C5A55537D
interface BVI1
ip address 10.10.10.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
password 7 030E5A00071A25444F
login
scheduler max-task-time 5000
end
ROUTER#
Everyone's tags (4)
2 ACCEPTED SOLUTIONS
Hi Elijah, Leo,
There are more issues than just those two. Elijah, your configuration is incomplete in many places. Please try to paste the following lines into your configuration mode:
! Begin here
interface Dot11radio0
  ssid ME-WIFI
    authentication key-management wpa
    exit
  channel least-congested
  no shutdown
  bridge-group 1
interface BVI1
  ip nat inside
interface Vlan1
  no ip nat inside
  no ip tcp adjust-mss
  no ip route-cache flow
interface Dialer0
  no ppp authentication chap pap callin
  ip mtu 1492
  no dialer-group 1
ip access-list standard NAT
  permit 10.10.10.0  0.0.0.255
ip nat inside source list NAT interface Dialer0 overload
no dialer-list 1 protocol ip permit
! End here
Best regards,
Peter
Hi Elijah,
Umm, sorry, I forgot the
ip address negotiated
on the Dialer0 interface. Please add it there.
Best regards,
Peter
Hall of Fame Super Gold
1.  Your NAT is missing;
2.  Your Dialer Pool is missing.
Hi Elijah, Leo,
! Begin here
  ssid ME-WIFI
    exit
  no shutdown
  bridge-group 1
interface BVI1
  ip nat inside
interface Vlan1
  no ip nat inside
interface Dialer0
  ip mtu 1492
  no dialer-group 1
! End here
Best regards,
Peter
Elijah,
Peter's right.  There's alot of missing parts to your config.  Go here.  Look at the attachment I made with configs for a router and an AP.
Have a look at those if you have the chance.
Community Member
Hi Peter/Guys,
Thanks for the quick response. I copied the configs and have the following output from the sh ip int b
ROUTER(config)#do sh ip int b
Interface                  IP-Address      OK? Method Status                Protocol
Dot11Radio0                unassigned      YES TFTP   up                    up
FastEthernet0              unassigned      YES unset  up                    down
FastEthernet1              unassigned      YES unset  up                    down
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  down                  down
ATM0                       unassigned      YES NVRAM  up                    up
Vlan1                      unassigned      YES manual up                    down
Dialer0                    unassigned      YES manual up                    up
Virtual-Access1            unassigned      YES unset  up                    up
Virtual-Dot11Radio0        unassigned      YES TFTP   down                  down
Virtual-Access2            unassigned      YES unset  up                    up
BVI1                       10.10.10.1      YES manual up                    up
NVI0                       unassigned      NO  unset  up                    up
ROUTER(config)#
The wireless access is still not working so I want to check out Leo's config.
Hi Elijah,
Best regards,
Peter
Community Member
Hi Peter,
Thanks...looks like it's working coz sh ip int b shows an IP address on the Dialer0 Interface. Now if only I could get the Wireless working. Thanks heaps.
Elijah,
Can you post the output of the show run int dot11radio0 please?
Best regards,
Peter
Community Member
ROUTER(config-if)#do sh run int dot11radio0
Current configuration : 547 bytes
no ip address
ssid ME-WIFI
    vlan 1
    authentication open
    guest-mode
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
end
ROUTER(config-if)#
Elijah,
You still seem to be missing the authentication key-management wpa in the "ssid ME-WIFI" subsection. Have you entered that command? It is possible that it is the default but I want to be sure.
Best regards,
Peter
Community Member
Hi Peter,
I have added that line, I had it before but still no connection. The physical interfaces seem to be picking the DHCP addresses but the wireless is not.
Re: cisco 857w wireless and adsl2+ configuration
Try adding this line under dot11radio0 interface:
encryption mode cipher aes-ccm
Hi Elijah,
Has there been any improvement in the meantime?
Best regards,
Peter
Community Member
Hi Guys,
Thank you so much I was able to have everything working using the configs Peter gave me and the configs Leo posted on another post. Everything is working now...now to play around with VPN and ACLs. Thanks guys.
2106
